03 navigator, possibly bad timing?
It wont turn over, my dad seems to think its bad timing or something along those lines. Its got 129k and otherwise in good shape, friend daily drove it until yesterday, when it started i guess sputtering/running rough so he shut it off and its been parked since then. Im buying it and curious what may be involved in fixing it. Any ideas or troubleshooting steps to start with would be awesome. Thanks!
I have not but that sounds like it could be the problem. I'm hoping its something simple. Im buying it to flip for a profit, paying 2k from a buddy, if it ends up being something major im sure worst case i can get my 2k back because overall its super clean and brand new tires, etc.
Ill have it today to mess around with a little before holiday get togethers and stuff. I have a cheap code scanner so ill try that first and let you know what i find.
This is the code my scanner read.
Cleared it and it started but very rough then died and thru CEL again.
P0340 - Ford
Type Powertrain - Ignition System or Misfire - ISO/SAE Controlled
Description
Camshaft Position Sensor Circuit Conditions
Cause
Engine running, then the PCM detected that the CMP sensor signal was missing
P0340 - Ford
Description
Cause
Here's the list of possibilities from the PC/ED for a DTC P0340 on your vehicle:
CMP circuit open
CMP circuit short to GND
CMP circuit short to PWR
SIG RTN open (VR sensor)
CMP GND open (Hall effect sensor)
CMP misinstalled (Hall effect sensor)
Damaged CMP sensor shielding
Damaged CMP sensor
Damaged PCM
However, a DTC P0340 will not cause a "No start" condition so you've got other issues.
See post #4 for prescient advice.
CMP circuit open
Damaged CMP sensor
Damaged PCM
Richi Rich
25
02-21-2012 06:29 PM
1955effie
01-19-2012 11:10 AM
_matt
12-01-2009 09:06 AM
