Also the next few starts after might be long ones too. That kinda threw me off the first time I experienced it, I was expecting it to start as normal after the initial long crank...
If you guys fill oil in the right spot after tear down they will restart almost normal
That's what I did, I primed the oil rail after I put it back on. There's a little port and I use a small funnel and fill with fresh oil until it's full. Everything must be kept very, very clean.
It took about a 6-8 second crank to get it running then seemed to run good. I hot started it and it took around 5-6 secs to start. Will this start to get better to? This is only the first time it's been on a drive with it after the pump. It never had a hot start issue before so hopefully I don't have to track a hot start problem down
Yes, it gets better
Sent from my mind thanks to the Internet and an app.
