1960 F-100 Frame Damage
Old 12-23-2014, 11:53 PM
bills86f150's Avatar
bills86f150
bills86f150 is offline
The engine runs however the radiator is pushed back towards the fan and is making contact
Old 12-29-2014, 08:57 PM
bills86f150
I went back and looked at the truck in better light and the damage isn't as bad as originally thought and it drove straight although the brakes need bled. I was able to buy it for $1750
Old 12-29-2014, 10:55 PM
Maltman's Avatar
Maltman
Maltman is offline
Right on! Congratulations
Old 12-29-2014, 11:31 PM
bills86f150
Now I just need a radiator and a front bumper to see how tweaked the frame horns are
Old 01-01-2015, 05:12 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
And a tape measure. Measure the frame diagonally, not only full frame, but at the cab mounting points and front of the frame to the front body mounts. Basically you can narrow down where on the frame its bent by making a bunch of diagonal measurements and comparing them. Good buy at that price.
Old 01-01-2015, 07:06 PM
economan's Avatar
economan
economan is offline
These truck's are soooo simple it's not a really big deal to swap the frame out.
there's gotta be a lotta decent parts trucks with good frames down there, and likely every bolt will turn right out, matter of a weekend & the frame's changed out.
When I was building my panel, rather than freshening up a whole chassis i simply took the cab & box off my pickup frame and dropped the panel body on
This was good Friday, early a.m. I drove the panel truck over to my friend's place easter sunday afternoon sans interior
Mikie
near ottawa canada
58 m-100 panel & 64 econoline p/u
Old 01-01-2015, 07:45 PM
spurredon's Avatar
spurredon
spurredon is offline
Very cool pics. I pulled the cab off a '59 and only broke one bolt during the entire job. They actually used decent fasteners when they put things together back then. The new stuff you really don't even need to tighten it as it will rust together quickly!
Old 01-02-2015, 06:38 PM
Maltman's Avatar
Maltman
Maltman is offline
don't know what parts this feller has-but, it might be worth a call
I ALSO HAVE MANY HUNDREDS OF OTHER MUSTANG AND FORD PICKUP PARTS FOR SALE
https://modesto.craigslist.org/pts/4828386250.html
Old 01-02-2015, 07:02 PM
bills86f150
I will give him a call and see if he has any parts for the truck and keep a donor frame in mind. Question, the back of the truck leans to the passenger side and after checking out the rear suspension the bushings on the rear shocks are completely deteriorated and gone. I am assuming this would cause the back of the truck to sag
Old 01-03-2015, 10:09 PM
rgs4x's Avatar
rgs4x
rgs4x is offline
truck parts
2 guys close to you for parts
Randy in Modesto 209-652-4815
CJ in Brentwood 925-321-6414
Old 01-20-2015, 12:10 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
I have a good frame
I have a good frame and maybe even a front bumper in modesto
Old 01-24-2015, 12:25 AM
Assy's Avatar
Assy
Assy is offline
Just thought id chime in and say thanks for the numbers it may help me get my 1960 going when i start the process. Also in turlock ca.
  #28
Old 01-29-2015, 06:44 PM
bills86f150
I had a welding shop in town straighten the frame rails. Best $100 I spent in awhile!!
  #29
Old 01-30-2015, 08:14 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
Looks good!
  #30
Old 01-30-2015, 08:29 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Wow its hard to get any work done for 100 bucks anymore! Trucks looks to in good shape now what?
Quick Reply: 1960 F-100 Frame Damage
