no parking lights,tail lights,dash lights
No taillights, dash lights, fog lights
Sorry to hash up an old thread, but I have a 2004 f250 super duty 6.no. My tail, clearance, dash, fog, parking lights will not come on when I start the truck. However, while warming up, they will come on. Sometimes after driving a few miles. Is there a relay somewhere that I may be missing? All fuses are good, stock radio, everything is stock except the work done to the engine. I'm kinda lost on this one.
The relay in the VSM is only in play when the light switch is in AUTO or when the VSM locks or unlocks the system and flashes the lights.
If one turns the switch to either PARK or HEADLIGHT switch, the VSM relay is not in the circuit, it is bypassed.
Focus on F17 delivering power and the main headlight switch (left side of the diagram above).
Bringing this back to life. Our truck started to do this exact thing. No running, tail, or clearance lights for a few minutes after starting. Replaced the headlight switch, but still happens.
Don’t think it is a fuse because we get power eventually to the bulbs. Relay? Which one, where is it located in a 2004 F350?
How did you resolve this problem?
Thanks
Thanks
Thanks
Thanks
We got it figured out. Because the lights out was only occurring immediately after startup when cold, they would suddenly turn on after a bit of warm up, I didn’t suspect a fuse.
Replaced the switch, no change. Started hunting for broken wires and noticed a fuse looked a bit odd, kind of deformed, melted maybe?
Pulled it out, swapped in a new one and we have lights again. Not sure how I had an intermittent fuse, but I did.
Check them first.
Check them first.
Okay guys I hate to bring up something so old but I’m in desperate need. I just bought a 2003 F250 7.3 and my taillights are not working. Turn the switch to parking lights and the only thing that comes on is the roof lights. No taillights, no parking lights, no tag lights. Turn the switch to headlights and the headlights come on. No taillights, no parking lights, no tag lights. My brake lights work fine. My turn signals work fine. I have check the voltage at the taillights, and I get nothing. I check the 8 pin plug under the bed of the truck, and only get power for the brake lights and turn signals. I’ve check every fuse in the truck. I’m supposed to leave Tuesday for work five hours away and I can’t think of anything else to try.
#29
#30
I am assuming the roof marker lights are factory? If we assume that, I was looking in the diagrams, the roof markers are fed from a splice s215 right after the headlight switch.
There is a tan/white that feeds power from the fuse box to the headlight switch just for the marker lights. We know that is good since your roof markers are working. Coming out of the headlight switch is a brown wire that feeds all the markers in the whole truck.. The first thing this brown wire hits is splice s215, which feeds the marker lights which are working. The brown continues on to the underdash fuse box. In the fuse box it splits out into the trailer tow parking lamp relay, and also splits into two brown wires, one feeding front parking lights in the fenders and grille, and the other brown feeding the rear parking lights.
I do not know where this splice s215 is located, but that would be the place to find. Apparently you are good till you hit that point, and after the splice, power is not making it to the fuse box and the tow relay area. If the front lights are working like projectsho89 was asking, then we know the wire from the splice to the fuse box is good, and where it splits in the fuse box can be a problem or afterward since in the fuse box tow area is where it splits front and rear.
