Fords brake controller/ braking system?
Rather than go by years, I would suggest checking with the manufacturer of whatever system the towable has you are considering. The RV industry turns on a dime so what one model has in a given year, may not be what another one the same year has (I run into this a lot). Search the Internet and the RV groups and see how it worked for them.
As I recall, the trucks now have a controller setting for hydraulics and maybe someone can say when they came into play, but I still would not trust it to work with all RV components. The manufacturers really don't play very well together. My after-market controller does, as do several others.
Just my two cents worth,
Steve
Steve
The original controllers didn't work in 05 but i think by 07 they did but not sure, the newer ones you just go into the information center and change it to what you want. Most of the actuator manufacturers make a adapter box to work around the problem or you can do just take two brake magnets strap them to the trailer frame and wire them in parallel with the actuator, that's how GM owners worked around it until GM fixed their system. The controller just wants to see current draw from magnets, the actuators just wants to see voltage, its heavy current draw is from separate source.
Denny
Denny
As rvpuller stated, the gm's were (and still are) a battle for some...
a buddy has a gm diesel that balks at talking to his 2013 winny bago 5er...
he's gone round and round with gm over it...
I sent him a post from another forum where they had to get an interface from carlisle to talk to his gm...
So far, our 2013 ford with the interface option to select hydralic or electric has worked on two different rv mfg's 5ers....
good luck !
good luck !
horsepuller
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-12-2002 04:51 PM
