Block lift vs add a leaf
i gota 95 f350 on 37s, its been lifted in the rear by a 4 inch block and add a leafs. My biggest problem is the axle wrap and having wheel hop when i loose traction. So should i just do all block lift 6 inches ? or leave it how it is to prevent wheel hop. And yes i know i need traction bars and true lift springs but i dont have that kind of money
Received 3,102 Likes
on
on
Amen Tom, blocks cause axle wrap period. I dumped mine and went with all leaf spring, procomp lifted springs are cheap, I got mine for 250 bucks a pair front or rear and they go from 4 to 6 inches. That included shipping JC Whitney. Even with the springs I am going to add ladder bars in the rear. I can still see were im getting axle wrap, just look at your drive shaft slip joint. Big tires, lots of power need something to keep that rear in place.
on
really, huh i wouldnt have thought ford would have put that big of a block on a truck thats made to tow. And yeah i know i need real springs i get that, im redoing the hole lift when im out of college. Im just seeing whats better for less axle wrap 6 inch block on the add a leaf, cus yeah the add a leaf definitely makes it ride pretty stiff.
on
all trucks have some sort of angled shim between the axle and spring.
size of the truck will determine the angle of the shim.
a 2 wheel drive F-150 may only have a 10 degree shim, where a F-350 4X4 may have a 30 degree shim.
i am not sure on the actual shim size, just using these numbers as an example.
a 4 wheel drive F-350 with snow plow prep that sits 26 inches from bumper to ground will have a much larger angle shim than a 2 wheel drive F-150 with only 12 inches from bumper to ground
huh yeah u must have a different axle then me cus my pinion angle is not that far up. And well sence this truck has a 4 inch block stock i guess i only have one add a leaf and a "spacer leaf", What i mean by that is that the last guy put that helper spring thats on the top of my leaf spring for a heavy load, on the bottom of the leaf to add like 1/2 inch of lift
