No cruise control. ...big red question # 1
Cruise Control self test
You can start with this thread. I couldn't get the self test to initiate. My problem was the plug connector on the brake pressure sensor on the master cylinder.
See if these threads help
https://www.ford-trucks.com/forums/1...conundrum.html
https://www.ford-trucks.com/forums/1...-question.html
https://www.ford-trucks.com/forums/9...ml#post8315477
on
Ok so to update everyone. The recall has been done. (Blue tag on the wires) I tried to do the self diagnostics but there was no response whatsoever but I don't think the indicator light works. It doesn't light up when everything else does when you turn it to run. I took it to a mechanic friend with a fancy smancy snap on scanner. The scanner registered all the buttons as they were pushed and all of the switches (brake, clutch....) checked out ok. It also discovered a circuit fault in the intake temperature sensor but I can't imagine that that would affect the cc.
