Bug out my Bullnose
So I do have the Duraspark then huh?
Is it possible to just run a solenoid only kind of thing and be done with it? Could the solenoid get power from the battery, then just power a coil to run the plugs? Is there something that simple out there? Something that can still run when the lights are off ya know?
Myself, I'm just going to rely on a tinfoil hat.
There is a lot of speculation about EMP and certainly research into the effect. Best known incident may be the 1859 Carrington event. Solar storm, yes, but the electromagnetic properties of such a storm may be similar to any EMP pulse.
http://en.wikipedia.org/wiki/Solar_storm_of_1859
I think the best bet on a bug out vehicle would be a mechanical injection diesel such as a 6.9/7.3 IDI. Don't count on any electronic goodies such as radios or GPS to continue to function. Transmission should be manual, or a full hydraulic A/T. Lighting and any other electrical essentials would have to be simple and robust.
The 1859 solar storm produced reports of telegraph stations acting erratically. I think this was largely due to the large area of overhead cables that collected energy. The collection area of a single vehicle is much smaller and I suspect the energy collected would be greatly diminished. Would it be enough to fry electronics? Maybe not, but the name of the game is preparedness. Possibly running wiring in metallic conduits, which are properly bonded to the chassis may help.
I hope we never see such an event. Reality is, we have more to fear from social decay and unrest than we would from a single EMP event.
No thanks to that. I'll probably just have to keep a spare aside and replace it when it happens.
Also think a lot of this was covered with carb and points conversions.
Relays and solenoids are a lot more robust that semiconductor junctions. A direct hit by a nuke will make everything a moot point.
I personally believe that only in the very worst cases would Duraspark trucks die...those modules are fairly basic, as well as robust. The biggest problem would be the power grid, with all those transformers blowing. Worst case has the power out for years, with millions dying before the power comes back, if it ever does.
It's all the wiring that act as antenna's.
Bringing the power surge right into -whatever- device.
The transistors and diodes in the DSII box would pop.
The electronic regulator in the alternator would go too.
Most windings would be fine.
You don't really have to worry about the ignition coil, or a 1G w/ mechanical voltage regulator.
Cutting the the core of it..
You don't really have to worry about the ignition coil, or a 1G mechanical voltage regulator.
Whether it would be wise to be "on the road" to "who knows where" with how much fuel to spare might be a whole n'other conversation to be had with those you trust and hold dear at that particular time... or better yet...PRIOR to..
#29
I have seen vehicles get a direct hit from lighting and still keep on going with no issues. Also I have seen lighting take out vehicles too. Lighting is one heck of a EMP too!
Years,years ago I took a direct hit in my front trees, I lost some electronics and others never affected. The work truck was not so lucky though! They had to replace just about every electronic modal in it LOL! I never did tell them it was lighting strike as that F*%$#%&^& company would try using my home owners insurance as the vehicle was parked at home when it got toasted.
I think the EMP is over rated by these stupid TV shows. Unless you are at ground zero, I doubt it would be any worse that a common lighting strike near by.
#30
