Year Model???
#31
F1R1KC26314
F1 = F1
R = V8 engine
1 = 1951
KC = Kansas City plant
26314 = 26,314th built that year
Do you also have this number stamped in the frame near the right motor mount? They're sometimes under a lot of grime, and hard to find.
F1 = F1
R = V8 engine
1 = 1951
Last edited by Jolly Roger Joe; 01-04-2015 at 03:29 PM. Reason: I originally put the wrong engine type in the post.
#33
You have a 1951 F 1 The tag is on the firewall. A late 1951 and 1952 the tag is on the glove box door . The number you want is on the right front frame on the top . Use some emery cloth or sand paper to find it . It's not stamped very deep. Texas is not hard to get a title. Now, about those front springs, are they in good shape, ? If so I would be interested in them, thanks.
#34
Here's my Patent Data Plate. Only the top numbers are stamped in and the rest is painted or silk screened on. It was wiped clean and I had to replace it.
Here's my Glove Box tag. My truck was built in August 1950. Some time after that, the 1951 glove box tags changed.
#35
ONLY the stamp on the frame is the legal serial number, if it matches the rating plate pictured or not doesn't matter rating plates can and often are switched. Only the frame stamp defines the year of the truck, doesn't matter what year the sheet metal is. Don't play russian roulette with your truck, get it titled in your name before you spend another day or dollar on it.
#36
#37
#38
#40
Hey Dgrant,
When we went to get the Title in our name here in Austin. We just had a tag in the glove box with the Vin #. The frame where the Vin# would have been was under our nice welded in IFS. All that was required of us was a $2 Vin Verification Form that any inspection place can fill out. They found the nice tag in the glove compartment & didn't look anywhere else & just filled out the form & faxed it in to the DMV.
In our case we had an out of state title & just needed the VIN verification to complete the process. If I were to do this again I would get the title work done BEFORE doing the Independent front suspension & obliterating the vin on the frame.
Good luck over there. Let us know how it goes.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Bret Sutherland
67
08-08-2019 12:14 AM
BaggedMerc
01-04-2015 11:30 PM
hot-rod
27
06-16-2010 08:23 PM
