2 speed rear end
By 1955 they are all electric. Willing to bet it is not fully engaged in high
usually caused by a dirty or rusty worm screw in the unit. You should first
pop the aluminum cover and examine it (dont shift it while the cover is off).
This cover also serves as a pivot support. Or take the whole unit off
for a bench test. two bolts remove wires and its off. dont worry theres no
wild monsters in there.
Hi, because the alum cover is also a bearing support-when off you will
see what I mean. as I said over time moisture will form rust on the
worm and bottom ball bearing causing it to be sluggish or just not being
free. With a good cleaning & oil should be good to go. Also in there is
a reversing switch that switches motor direction (high/low) Napa has
that. Good time to replace. Napa also has electric motor and the red
shift button. (or they will get it from warehouse)
sam
sam
kbengt
02-02-2012 11:52 AM
48f6
01-11-2008 09:45 PM
mshoemaker
10-31-2007 07:19 PM
