Coolant leak after oil/EGR cooler
Guys,
I just got my truck back from Ford - EGR (bulletproof) and oil cooler replaced. There is now a coolant leak dripping down the backside of the engine passenger side. Blue hose seems dry but I can see some coolant under it in the valley. It is a steady drip. I am bringing it back to Ford. Any ideas - blue hose seems to be on good. It is hard to see and tell without ripping it apart.
I really wanted to do this myself, but with the holidays and an upcoming trip, I did not want to rush myself. Anyway, pretty annoyed right now
Guys,
Sent from my Telegraph using IB AutoGroup
[QUOTE=Yahiko;14925496]Was it also dry at the outlet on the cooler housing
where that blue hoes connects at?
I'm not sure b/c there was a little puddle down below and it was hard to reach my fingers back there. I think that is where is it coming from. I don't think it is any heater hoses - they all look good and dry. It made a 12" puddle on my driveway so it is not a trivial leak. I dropped it off for Ford to look at it. I'll let you know what it turns out to be.
I bought all the parts for this and brought them in so I know it is not an old gasket problem.
Yeah, I know - what I meant was an "old" gasket problem - reusing something that should have been replaced. I bought new seals and gaskets for everything that came off. I think this is more of an install problem than a gasket failure.
I did that with mine. I had the system under a vacuum
and it just would not hold. So I started poking around and
heard a noise at the blue hose. Gave it a little wiggle and
twist and the vacuum quit dropping and held. So I then put
some pressure on it and let it sit. No drop so I was happy.
Sean
Marry Christmas
Only 33 to go till 10K
Sean
Marry Christmas
EddieEX10
04-19-2010 07:41 AM
