T Bird/Mark VIII IRS HUBS WROM
T Bird / Mark VIII IRS Hub Wrong Bolt Pattern?
If you don't know it you can change your T Bird or Mark VIII Hubs and rotors to Mustang IRS hubs and rotors to match CV IFS fronts hubs. New Mustang IRS hubs (5 x 4.5) Ford part number FMS-M-1109-A run about $150@, less bearings.
SOLUTION
IRS Machining Services They'll drill yours, clean them up, install new lug bolts and send them back for $75.00. That's 1/2 the cost of 1 new hub! They'll also redrilled your rotors. But new rotors can be had at your local auto parts stores for $40.00 on up.
Seems like a pretty good deal.
SOLUTION
SOLUTION
IRS Machining Services They'll drill yours, clean them up, install new lug bolts and send them back for $75.00. That's 1/2 the cost of 1 new hub! They'll also redrilled you rotors. But new rotors can be had at your local auto parts stores for $40.00 on up.
SOLUTION
Thanks for the info. That's what I'm going to do with my Mark VIII IRS. Dave Held has the rotors to fit Mustang IRS hubs.
lcars2
11-09-2003 12:03 AM
