Figure this truck out
Some of the Ford loyal will dispute this but Ford was notorious for running production changes. It could be possible that a late production 67 could have some 68 features. I have ran into late production Fords using parts from the next year. I've even owned a couple.
ND listed differences I did not know about and there are a couple more according to Fordification. One is a 67 only ash tray and also the instruments are wired in differently.
on
Yea but we'll never know if it was a mid yr change. Or the guy came across all the stuff at some point from a junk yard. So many yrs have going by, just like were all doing with 3g & o/d trannys,, Oh well nice looking rig setup for the outdoors man. Plus PO has even changed the motor out..
Orich
Orich
Orich
Orich
Here's a pic of a 1968/72 F100/350 A/C-Heater Control Panel with factory A/C (C8TZ-19980-A). It's similar to the 1968/72 heater only control panel.
on
So it's must be a like a Bast Ard truck!
orich
Left: Here's a pic of the 1967 only dash, notice the 3 ***** that are used with the heater.
Right: Here's a pic of the 1968/72 dash, notice the heater control panel.
In order to install a 1968/72 heater panel in a 1967, you'd have to cut a hole in the dash...and would also have to swap in a 1968/72 heater...since the 1967 heater is 1967 only.
Can you tell a 1967 ashtray from a 1968/72 when it's closed?
btw: I looked at the pics again, the left door is from a 1967 as it doesn't have a lock ****.
The hood side emblem is 1967, but the marker lamp on the front fender wasn't installed on F250/350 Camper Specials until 1968.
As you know, I've been to Ketchikan 4 times on AK cruises (actually we've been on 5 AK cruises, the one we took in 2013 didn't stop there).
2004, the first year I was there, a house was burning that was located above the tunnel that takes traffic from the downtown area.
Came back in 2005, there was an vacant lot where the house stood...it was still vacant in 2012.
#28
I was more asking how the system worked than speculating on what someone might have done back then.
#30
IMHO this truck was put back together with JY parts. Rust,body damage,etc. Who knows, a JY themselves may have pieced it together and then sold?
