1999 f350 start and then no start
you're talking about the icp sensor ....driver side....top of the block. Right?
was under the impression that if that sensor was bad and you disconnected it, truck would start but run rough? I have not replaced that sensor as it is fairly new and is not leaking. I have read that the icp and ipr communicate with each other? I guess it could be bad without the telltale oil in the plug Right?
ICP is injection control pressure; the hydraulic pressure supplied by the high pressure oil pump. That pressure is what actually causes the injectors to send fuel out through the nozzle when the injector is actuated by the injector driver module (IDM). The ICP sensor monitors the pressure in that system, and must see 500 psi minimum ICP before the PCM will send a fuel delivery command signal to the IDM. There are several possible causes for low ICP, but we don't know for sure that is your problem yet.
With it unplugged it will idle normally but run rough on higher rpms since some default amount is supplied it it's absence.
I only have my superchip reader. I'm aware it can only read general codes and no live data. iv'e been working on getting my sons friend who is a diesel mech to bring his ae to my house but hes an hour away and being its the holiday season hes pretty busy with family things......im kinda on the back burner
Happy New year guys.......well for some!
Was finally able to get my truck on a scanner after many days of troubleshooting.
Diesel mechanic phoned me back yesterday an gave me the news. Hpop only pushing 50psi. Very disappointing as it is a 40 month old t500 with less than 40k miles on it.
Currently trying to contact Joey through Clay for info as to what could have went wrong.
Feel like it has to be internal as i know of trucks with leaking hpops that can still build enough pressure to start.
Will let you guys know more when i find out more....Thanks to all the guys who were helping me out!
Thanks Bonanza.
I replaced the ipr . Brand new one on it. And I hope you are correct with your assumption and hope joey will rebuild it under warranty. In the meantime I have feelers out locally looking for a used pump. Dont care to have to drop 650.00 on a pump from ford when a used pump can get me on the road again (temporarily) ,then I hopefully can get the t500 repaired and reinstall it at my leisure....when time and temp permit.
#29
Hi Paul,
Looking like I will Probably have the shop do it. I did the last swap but since then I have lost my garage. It was on my dads property and he moved into a condo. Hated like hell to see it go......many times i have wished we still had it. 30x30, two bays, fully equipped,heat and ac, bathroom with shower for those extra filthy jobs.......really miss it!
Anyway, trying to get a used pump as a temp fix until i can find out from joey if he will warranty it , since I still believe something internal gave way. Thanks again for you help!
Bill
Bill
#30
