1975 ford f-350 throttle linkage
i am in need of some help. i have a 1975 ford f-350 with 360 FE 2bbl, i need to find the linkage rod. i have the pedal assembly, i have been battling an up hill battle i have been working on finding parts after all the sheet metal and bracket out of the engine compartment area were stolen as i was doing the engine swap, i have found a bunch of the parts but am unable to locate this, i could make one but kinda want original. please help with info, have check local yards and nobody has one.
Throttle linkage... you're going back to the funky "trapeze" set up? If you're not doing a true restoration, head to the 'yard and find a 76-79 Dentside and grab its linkage and ball stud hardware. Alternatively, Holley offers linkage kits for very little money... in the end, a salvage yard trip will cost less and be more fun.
'course that was over 10 years ago
As far as the restoration its not going to be a factory original restore, it is going to get 4X4 upgrade, i have a 1988 ford f-350 Dana 60 dually front axle, I am working on acquiring the rest of the parts for the swap. So as far as it needing to be factory original it not 100% necessary I just want as much original stuff on the truck.
No 'funky trapeze' bellcrank (located at left rear corner of intake manifold) after 1972.
Welcome to FTE
D5TZ-9747-B .. Rod-Accelerator Pedal to Carburetor-11 1/2" long / Obsolete
1975/76 F100/350 360/390 / 1975/78 F100/150 302 / 1975/78 F150/350 460 without Speed Control / 1977/78 F100/350 351M/400 / 1978 Bronco 351M/400, ditto 1979 before serial number DG0,001.
USD INC. in Phoenix AZ has 2 = 602-253-7111.
MILLER OBSOLETE PARTS in Binghamton NY has 20 = 607-722-5371.
D4TZ-9826-A .. Clip-Accelerator Rod to Accelerator Pedal / Obsolete
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 96 = 800-543-4959.
Lower pic:
Lower pic:
55fordf100Gramps
04-11-2013 06:20 PM
tdmoparguy
01-26-2010 08:11 PM
ddh1
12-03-2009 11:22 PM
77dream
07-30-2003 08:54 AM
