alternator
Old 12-20-2014, 09:23 PM
rustyleerusk's Avatar
rustyleerusk
rustyleerusk is offline
alternator
Here's my problem. Found the wire attached to the STA wire hanging loose. After looking at all the digrams i can find they all say the STA wire goes from the alternator to the regulator but the regulator has the factory plug installed with all the wires there and going to somewhere else, no place to plug the wire i found into. The alternator only has 3 wires coming off it ( batt, field and stator). This is on an 82 f250 without air. where the hell does this wire go???
Old 12-20-2014, 10:30 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
It was connected to the choke on some, but not many, of the trucks. There's about 7 volts on that connection, and Ford set up the electric choke to use that voltage.
Old 12-20-2014, 10:42 PM
rustyleerusk
manual choke on this one. So the battery and field wires are all that should be coming off this alternator and hooked up to anything?
Old 12-21-2014, 05:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
It didn't come from the factory with a manual choke.
Clip it off if you don't like it.
Old 12-21-2014, 07:17 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
You must have the gauges in the dash. Here's the diagram.
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Yes, only two wires then. Here's your wiring diagram:
Old 12-21-2014, 09:27 AM
rustyleerusk
thanks guys
Old 12-21-2014, 04:37 PM
rustyleerusk
Found the problem. Small drain somewhere in the electrical, probably why the PO installed a master battery disconnect switch
Old 12-21-2014, 08:25 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Pull fuses one at a time until the drain goes away. Typically it will be an aftermarket radio.
Old 12-21-2014, 08:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wasn't David saying -in another thread- that his son's truck needed an ignition triggered relay for the stereo amp?
disconnecting/isolating the battery gets old really fast.
oldtruckolderguy
Electrical Systems/Wiring
01-16-2009 08:56 PM
zeus77
08-22-2008 08:48 PM
sum_weirdo
10-28-2007 09:38 PM
soutahranger
01-12-2004 11:04 PM
beartracks
10-08-2002 07:51 PM
Quick Reply: alternator
