Here's my problem. Found the wire attached to the STA wire hanging loose. After looking at all the digrams i can find they all say the STA wire goes from the alternator to the regulator but the regulator has the factory plug installed with all the wires there and going to somewhere else, no place to plug the wire i found into. The alternator only has 3 wires coming off it ( batt, field and stator). This is on an 82 f250 without air. where the hell does this wire go???
It was connected to the choke on some, but not many, of the trucks. There's about 7 volts on that connection, and Ford set up the electric choke to use that voltage.
