Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-20-2014, 07:56 PM
1995F250351's Avatar
1995F250351 1995F250351 is offline
1995F250351 is starting off with a positive reputation.
@JacksonVidal
95 to 92 Motor and tranny swap
Hey everyone
I have my 95 F250 with a 351 and a 5 speed, now... Just today I think, I'm pretty damn sure but not certain, that I blew my Slave Cylinder... My clutch pedal goes to the floor and stays there and my clutch is still engaged. so here is my dilemma... Keep my 351 with 298,000 on it in my truck and drop the tranny and buy a slave cylinder, or yank my 92 351 and 5 speed with 170,000 from my parts truck and replace both, then build my 95 351 up like I've always wanted to... the major question here is, will all the wiring harnesses match up? and if not, is it a huge deal? And by the way, Does the 92 produce less power than the 95? and If so, because of the Flat Tappet cam? But on the other side... 128,000 less on the 92 so it might have more ***** than the 95?
Thanks in advance!
__________________
1995 F250 351W 5 Speed 4x4
-Twin 62mm throttlebody
-K&N Air Filter
-3 inch Exhaust
-Leveling Kit
Old 12-20-2014, 08:19 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
It will if you don't try to use any '92 wiring on your truck, in other words you have to remove the upper intake on both motors and disconnect all wiring right on the engines before the swap
Yes
Yes
Doubt it.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1994 3.0L 5-sp x-cab Ranger 3.45, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Old 12-20-2014, 08:23 PM
@JacksonVidal
Quote:
So does that mean like plug and play from harnesses? Or will some things need to be re wired? And also, how much horsepower more would the 95 make over the 92?
__________________
-K&N Air Filter
-3 inch Exhaust
-Leveling Kit
Old 12-20-2014, 10:15 PM
Conanski's Avatar
Yes the '95 engine harness will plug right into the '92 motor.
There could be a big difference in power between these motors, on paper there was virtually no power change over the years but on the street some of the early flat tappet motors were only slightly more powerful than the 5.0 which wouldn't maintain highway speed into a head wind in these heavy trucks.
__________________
Old 12-20-2014, 10:33 PM
@JacksonVidal
Oh really? would it at all be possible to swap the cams out? Sounds like a dumb question but I want to be sure...
__________________
-K&N Air Filter
-3 inch Exhaust
-Leveling Kit
Old 12-20-2014, 11:16 PM
Conanski's Avatar
The '92 block won't accept the later roller cam assembly but you could plug in a HO spec aftermarket flat tappet cam like the Crane 444232.
__________________
Old 12-21-2014, 12:07 AM
@JacksonVidal
Awesome, Thanks for the help man!
__________________
-K&N Air Filter
-3 inch Exhaust
-Leveling Kit
Similar Threads
95 cab and engine swap onto an 89 frame and tranny (clutch problems) Marteney 1987 - 1996 F150 & Larger F-Series Trucks 6 01-05-2014 02:33 PM
'95 F150 Eating slave cylinders !!! farmer07 1987 - 1996 F150 & Larger F-Series Trucks 3 12-28-2009 07:54 PM
93 I6 to 351 swap help USDM EG Engine Swaps 6 05-08-2008 10:56 AM
Another clutch problem Hardwareman Ranger & B-Series 4 08-28-2004 10:36 PM
hydraulic clutch adaptation bluestang65 1961 - 1966 F-100 & Larger F-Series Trucks 0 02-09-2003 06:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
