Front/rear wiper and washer not working
I have checked fuse #11(30amp). Have 12v going through fuse.
Where does the power go to? There must be a relay that the 12v goes through.
Driver express window relay is also not working properly. 5 amp fuse checked so is it a GEM issue?
Thanks in advance!
Thanks in advance!
This all started when I replaced the heater core. When it was all back together, the truck started and warmed to normal temp. I turned off the truck to check for leaks and it would not start. I had a thread about PATs and Theft alarm but it turned out the starter decided to disintegrate at that moment unknown to me.
I believed everything worked and used the wipers and washer on the road.
Next day the wipers and washer and the express drivers window were not working.
Today I removed all of the remote start wiring right to the bone. Checked fuses and relays. I have power to the #11 fuse but do not know where it goes from there to work the wipers and washers.
Any help appreciated!!!
RichardinVirginia
1999 to 2016 Super Duty
04-11-2016 06:29 PM
gasturbo
1997-2006 Expedition & Navigator
09-18-2015 02:26 PM
wxbean
02-27-2005 10:58 AM
