Tragedy Has Struck my Ford
#46
The 3:55 ratio is a mathematical expression that corresponds to the number of teeth in the ring gear divided by the number of teeth in the pinion, so yes, the number of teeth matter. Keep in mind the pinion and ring gear are a matched set, so don't start mixing from different diffs or packages.
Also noticed your tag does not indicate limited slip. If you are building a diff, this may be something you wish to address.
#47
#48
#49
Rest assured I had to redo this one because I hadn't realize I did it incorrectly until I took the picture, it was not done incorrectly on the driver side.
#51
#52
#53
Update:
I bought the 30 gallon rear tank for my truck from LMC and have been modifying it to have a flowing & efficient manner to work with the EFI 2.0 I have. Heres what I have done this past weekend
Unboxing Aeromotive Phantom 450lph
View of the mount for FP
Cutting 3-1/4" hole (lots of WD-40 used in the making)
Cutting the hole for aftermarket Sending unit and spraying any marks made with anti rust paint
Installed both units into tank
Wiring the both units and dressing / protecting the wires with looms (had to make the connector on the FP to match the housing used in the EZ EFI Kit.
#56
#57
Its actually a whole fuel pump, baffle and mount assembly http://aeromotiveinc.com/wp-content/...x-1024x680.jpg of course more than whats in the picture. It is a very impressive system if you ask me.
Dusty is this a rhetorical question? If not Im not too sure, I was planning to have one at each door... It might suffice, all I know is Im not letting the truck burn down again!
#58
But the next question is how, just drill it and leave the exposed metal or dab some primer over it and silicon the screws?
#60
