Tragedy Has Struck my Ford
#31
In the Picture below (A) is the left over sediments from my speedogear.. Still trying to figure out which one I had to replace.
Figure (B) Shows the tailshaft bearing and seal for my transmission. The tailshaft housing had to be replaced due to being warped, it seems the gas from the front gas tank burned the hottest... Ive had to do a very detailed clean up on the transmission.
This engine is starting to come together..Still missing a few details, overall its getting there!
Corner shot
Back to sleep,
Anyone who has been following this thread, what is your input on the speedogear incident.. What would happen if I use the incorrect speedogear? Would the only issue be speed sensing giving false reads?
Corner shot
Back to sleep,
#32
#33
This is going to be a challenging task. I will be putting it into a new truck, with a 9 inch rear at 3.53 I believe 31 spline... I hope this is the correct info Im providing
#34
#35
#42
#43
Changed the rear brakes today, Shes getting there slowly...
Im going to need help identifying my rear end guys, this is what I got... I believe the tag Reads "WD R - 2L2R" "55 8 8S814A" I would like to buy a rear end to handle the engine or am I wrong and it isn't necessary to change from stock?
#45
This is amazing news!! I have a whole rear end kit I bought for my 86 that I never installed, this gives me a warm fuzzy feeling, I assumed I had a 9 inch rear since it was an F100. Does the teeth on the differential matter? How many teeth is my gear?
