Tragedy Has Struck my Ford
Sorry, about your truck. I was very lucky with my 1985 f-700 aerial lift truck. While I was on holidays, my employees were doing a pruning job. Lance was in the bucket at the time when, Mason yelled out the truck is on fire. Lance got down out of the bucket, ran for the fire extinguisher and put it out. Very lucky there was only about $700.00 damage to the wiring. I still had about $50,000.00 to pay on the loan.
What happened was one of the hydraulic brake lines burst spraying ATF fluid all over the hot engine. As I said I got very very lucky.
Fuel hose degrades from the inside, mostly. It looks fine, but it ain't. Even 3 or 4 psi from a mechanical fuel pump - it's pretty scary how far and wide fuel will spray when a hose splits. If it's more than a few years old it's cheap insurance to replace. Use new clamps, too.
Well with the kits Ive purchased, both 1.0 & 2.0 (Current) they include a very nice set of hose and hose fittings Hose is SAE 30R9, from what I understand this is a very reliable and durable hose. Granted it still melts in high heat...
What does the sheathing on a fuel line have to do with the cam, or warranty?
Any Russell, Earl's, Aeroquip, etc.. hose has a suitable liner for the fluid it is carrying.
ETA; not NEARLY as far and wide as @45 psi. (about nine times as much as a carb)
Sorry for your loss
Sorry for your loss
Comp Cams is the company that owns the Fast Company that produces the fuel injection system. The lines "are specifically engineered with the lines provided, anything that is not in the kit will be considered as altering of the product in which will void all warranties."
I was not specifically talking about my cam.
That's true Id hate to lose my truck and my man cave..
Bummer. Sorry to hear about your loss.
The coolest thing I ever saw was an old grizzled man driving a 50's Chevy pickup when it coughed and died pulling away from a light. He popped the hood and it was on fire. Without missing a beat and as cool as the Duke himself, he pulled out a knife, cut the upper radiator hose and the spray put out the flames. He then pushed the truck to the side of the road.
Good luck on the rebuild and don't forget the fire extinguisher.
Man that's awesome, I aspire to be like this gentleman in the future, I always have a nice assisted pocket knife but I wouldn't have thought to do this.. now I will haha
I don't know if it's "paranoia" though fire is one of those things that bothers me. Everyone here at a site like FTE has truck fever to some degree or another and takes pains to keep 'em running. Whether it's modern computer controlled rigs with faulty brake switches (or was it the cruise control?) or vintage trucks and and critters chewing on wires, leaves in the heater box, it all adds up to some level of concern.
Sure, that's what insurance is for but it's not going to replace all the hours/days/weeks spent repairing or restoring. Have battery cutout switch on the 64 and go around the house unplugging everything if going away for a few days.
As you can see I still had the FRAM oil filter, I didn't get to fully break it in :/
I started taking everything apart,
1. valve covers come off.. no problem
2. gasket melted onto heads.. huge pain to scrape off
3. Remove Intake
4.Start removing head bolts .. One of the heads on the bolt strips on the passenger side!
4.1. Bolt extractor.. doesn't work
4.2. Grind and chisel bolt out.. No damage to heads!! Very salvageable
5. Notice rust on Cylinder walls, Honed cylinders 1,3,5,7 & 8 (It seems the water from the fire fighters made its way into the cylinders)
6. Disassemble heads
7. Sand blast heads, intake, valve covers..
To Be Continued...
Interesting to see the blue paint reemerge. All that black stuff is mainly soot. Nasty clean up job, but looks like you had a lot into this engine already. Don't think the starter and alternator will make it. Fire may have damaged wire insulation internally.
I read years ago that fire damaged parts were quite useable. Some engine builders felt that the heat cycle seasoned the castings and made them more stable. I'd be concerned with warpage, but I don't think the block or internals would be affected.
How did it look in the crankcase and the lifter valley?
This rise from the ashes will be interesting to watch. I lost a couple parts vehicles to a grass fire last year. One was an Explorer with the 8.8 disc brake LS rear. Have not scrapped it yet, may look over that diff before I do.
Lifter valley had no imperfections that I saw. Pushrods, tappets and roller rocker arms were in great shape. When I get a chance ill post pictures of what I have spread out
Merry Christmas!! I started cleaning up the AOD yesterday, it was going smoothly until I noticed the rear seal of the rear shaft housing looked to be damaged. I opened the housing to find the speedo gears melted and broken and my rear sleeve had fused with the seal. Im looking online to figure out what I need to buy in order to have the transmission in working condition, Does anyone know the number of gears my 2WD F150 takes for the speedo? Im also in need of a good AOD mechanical diagram.. Once again Merry Christmas!! Pictures will be up later today
Unfortunately I scrapped the Truck but I did come across an old picture I took a few years back..
#28
Started working on the tranny, it was a very strenuous task. The transmission had received more damage than expected. The o-ring on the dipstick tube melted, the neutral safety switch was ruined. The tail shaft is warped, speed sensor melted and needed new gaskets. Changed the torque converter for fun. A higher stall TCI than the original one installed.
Sandblasted the heads, block and valve covers. This is the finished product of the covers.
Finished product after sandblasting & assembly (Teaser of new tranny Dipstick )
Assembled Heads
Organization is always important. Its crucial everything goes back as it came out..
The process is tedious making the progression slow. I will follow up with the block 90% assembled...
Assembled Heads
