boost problems
boost problems
truck use to push around 27psi of boost when i got the truck about a year ago. now when truck gets to around 22pis if starts to fall to around 15. been thinking about taking the turbo off and cleaning it and even putting a wicked wheel in it. are the any other sensors i can check and clean before i jump straight to the turbo?
Next check the EBP sensor, depending on the year it will be located either on a stud next to the thermostat housing or just below the FICM and is attached to the drives side exhaust manifold via a steel tube, remove the sensor and pass a piece of stiff weedwhacker line through the tube and into the exhaust manifold to ensure that the tube is clear.
If your truck has the EGR throttle body you can remove the EGR throttle body and remove the throttle plate then reinstall the throttle body as the plate is unnecessary and can cause boost issues, the throttle body is located where the air enters the intake manifold.
You also need to check your charge air cooler piping and clamps. This sounds like you have a split in a pipe or a loose connection which let's off the high boost, a leak, as opposed to a sensor issue or boost problem at the turbo. Just for testing, you may also wish to check and clean map sensor, Baro, IAT2, MAF and IAT1, while you your checking tubes for MAP and EBP. I would also get some way of reading these sensors as a bad one can be a problem. Finally, do you have an epintact EGR, and can you clean it and do a relearn for the EGR and verify it is working?
