Help With No Oil Pressure After Upgrade
Old 12-20-2014, 07:17 AM
sweetlou1's Avatar
sweetlou1
sweetlou1 is offline
Question Help With No Oil Pressure After Upgrade
Ok, I guess we aren't the sharpest toll in the shed. We lost oil pressure! Information you need is this is a '72 true 390. We measured the stroke. Motor is probably a reman, however the truck itself has only 64K which I have all the documented paper from the original owner. We changed the intake manifold to an Edelbrock performer and carburator, replaced the old distributor with a new HEI, new water pump and mechanical fuel pump. New plug wires and everything bolted up to fire the motor. Before starting the motor, we pulled the oil sending unit and cranked to make sure the Dizzy was in place. Oil squirted out, and that was a good thing.
So now we fire the motor which started right up, and we have no oil pressure. Checked the in cab, as well as put a mechanical on this. Both show nothing. The truck was a daily driver and drove it into the stall before the upgrades. So please, anyone with any thoughts let us know.
Old 12-20-2014, 09:44 AM
instig8r63's Avatar
instig8r63
instig8r63 is online now
Pull the distributor out and inspect the oil pump driveshaft. Get a 1/4 drive socket on an extension and spin the oil pump driveshaft counter-clockwise with a drill and see if you get oil pressure.
Old 12-20-2014, 12:07 PM
Gembone's Avatar
Gembone
Gembone is offline
also to be sure the pump shaft didn't fall into the pan
Old 12-20-2014, 02:36 PM
sweetlou1's Avatar
sweetlou1
Pull the dizzy out again and it should just clunk when you drop it in so you know the shaft is all the way. This HEI just doesn't do that so we tried again and now with the mechanical we show good pressure. I still don't trust it though. I will keep an eye on it
Old 12-20-2014, 06:00 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Isn't that one of the most sickening sounds you ever heard when pulling a dist and you hear the pump shaft fall. Been a long time though.
Old 12-21-2014, 11:07 PM
orich's Avatar
orich
orich is offline
Maybe check the HEI that it has the 1/4 hex shaft and not damaged or stripped. And may be since it made off "SHORE" all kinds of things can get shipped to the US.
orich
Old 12-22-2014, 01:05 AM
sweetlou1's Avatar
sweetlou1
Originally Posted by orich
Maybe check the HEI that it has the 1/4 hex shaft and not damaged or stripped. And may be since it made off short all kinds of things can get shipped to the US.
orich
After pulling it out a few times we finally got it to seat and build pressure.
jeff8362000
11-09-2009 08:59 PM
chevygoneford
1978 - 1996 Big Bronco
04-02-2007 12:30 PM
johnstechhelp
11-30-2005 10:35 PM
houlis
10-24-2005 02:31 PM
78 Swamp Donkey
09-18-2003 06:04 PM
Quick Reply: Help With No Oil Pressure After Upgrade
