Smell my dipstick.
Old 12-21-2014, 01:55 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
Just be very clean when sampling,or you will not get accurate sample.
Old 12-21-2014, 05:46 PM
sgarder's Avatar
sgarder
sgarder is offline
Hey guys I don't know what year Ford discontinued this. The torque converter can be drained and refilled with fresh fluid also. I don't remember for sure if there is a rubber plug on bottom of trans housing (possibly only on 150?) If no plug, the dust cover bolted to front, lower, of the transmission housing can be removed. Turn the engine over to see if a drain plug is in the converter. This lets you drain a lot more of old oil out of the tranny.
Old 12-21-2014, 06:52 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Old 12-21-2014, 06:59 PM
crop harvester
Our Resident auto trany Guy, Mark K. has a good write up on trany oil change [transfusion],If I remember right, you dont need to drain torque converter using His instructions.
Old 12-22-2014, 06:58 AM
CGMKCM's Avatar
CGMKCM
CGMKCM is offline
Originally Posted by white Buffalo
I think they are the same. For what it's worth, the pan on my 2003 2WD F-250 is the same as the pan on my 2000 4WD Excursion. What is different is the filter. The actual filter element is the same, but the pick up snout reaches deeper on the 4WD filter. But you can use the 4WD filter in the 2WD model, this is what I have been doing
From what I have read there are Two different pans (ford) f81z-7a194-ba (4wd, deep) (ford) f81z-7a194-aa (2wd, shallow). The shallow pan holds One quart less than the deep pan.
Old 12-22-2014, 09:49 AM
white Buffalo
Yep, sorry for the mistake.
Old 12-22-2014, 11:25 AM
M-S-G's Avatar
M-S-G
M-S-G is offline
I have confirmed that is the case. I appear to have the deep pan. Size of pan also seems a factor when ordering tranny screen, although people say shallow pan will work with deep pan screen.
Oh, and let's make sure nobody calls that thing a 'filter' ever again
Seems to me calling it that is what makes ppl replace them for no reason.
StrokinHer01
19
03-31-2018 01:32 PM
twinturbostang
1997-2006 Expedition & Navigator
09-12-2010 12:55 AM
gasgrunt88
18
06-08-2009 03:45 PM
Trek93023
1997 - 2003 F150
27
04-11-2006 05:48 AM
sherriehicks
Bronco II
09-09-2003 06:45 PM
Quick Reply: Smell my dipstick.
