Truck won't start.
Truck won't start.
I have a 1987 F250 Diesel with a 6.9 n/a Diesel. I just replaced all the injectors and IP. Ran it for a few days now it won't start. Found it had air intrusion and fixed that. I have fuel to the injectors and I know that for a fact because I loosened the caps on top of the injectors and now have fuel coming out of the caps. I have the aircleaner off so that's not a problem. Checked the FSS and have power there. What am I missing? I timed the IP with a meter from Gary from "oil burners". It was off by 3 degrees but after I changed the timing it ran for a couple days great. It has to be simple just can't figure out what I"m missing. I turn the key and she turns over fine, just won't start. Replaced the starter about a month ago. Also have the block heater plugged in. I adjusted the starter switch in/on the column this morning. It stopped working sometimes when I turned the key but after I adjusted the part down towards the firewall it turns over every time. Hadn't thought of that.
I replaced the switch on the steering column and nothing happened. Jumped from the positive battery terminal to the terminal on the IP. Nothing there either. Turns over fine but still no start. Checked for fuel flow to the return lline and there is a fuel there, not much but there is fuel flowing out of the pump.Good fuel flow from the tank to the IP thru an electric fuel pump
on
I'm glad you got that solved. That'd be hard to diagnose without knowing alternate fuels were used, and a good lesson to keep in mind for the rest of us. We can plug in the block all day but solidified or gelled fuel won't pump!
Would save some time if they told us up front all the details.
yup running garbage doesn't work.
Sorry I asked those perfect people out there. As for being free, you might want to check again because it hasn't been free for years. I realize I didn't add the "vegoil" part because I had been running straight Diesel for a couple days before it stopped and didn't see the reason for throwing it into the conversation. As for saying it was "vegoil" I can't say it was as I didn't open up the IP. For all I know it might have been gelled Diesel since it's been cold here and the fuel was from last summer before I went to Guam and the truck sat for three months and not started. As for running garbage in my tank, I'd say some of the Diesel fuel ranks right up there under the garbage label because in the past I've heard and seen what some of the stations sell as "Diesel". Vegoil garbage? Your absolutly right but then some of us hate to see the throw away society we're living in that think instead of fixing or recovering what might not work, they work to recycle it. Now your going to call me a tr hugger? No thanks. I have no use for those people. I just can't see throwing something away that can be used or reused. My 2cents
Anyway, sorry if my other posts seemed abrasive or offensive.
No offence taken, just wanted to set the story straight. If I had been running vegoil when it wouldn't start, I would have said it. I can't vouch for the fuel around here one way or another and like I said I was away for 3 months working where I couldn't take my truck. I have seen posts where a guy, not me will ask a question and get called everything under the sun because he didn't know something. That is a great way to lose a good person thru no fault of their own. When somebody firsts gets into Diesels, they don't have a clue. When I started I didn't know what was good or bad. I asked questions and got some good advice. I was lucky. I've seen others post and your think they didn't know the differance between gas and Diesel but they leaned. I'm not calling anybody out and won't but before they start calling people names and getting in their case THEY might find out what the guy is asking before they condem them. I'm not on here all the time and don't see where anybody jumps down the posters throat all the time so I can't say how often it happens. Most of the people on here have respect for others but there seem to be some that think they can do no wrong.
on
Thats a funny subject, I always ask the gas attendant did you guy's winterize your diesel yet? they all look at each other and shrug there shoulders. I had on guy go inside and ask the owner of the station, he didn't know. So to be safe I always add power service to my fuel tank and aux. tank. I have been stuck with gelled fuel before and dont want to go through that again. But we all have to be careful what we are putting in our tanks, if you do bio, good for you, doesn't make you a tree hugger by no means. But that is an important piece of info when diagnosing a no start condition. Just my 2 cents and hope nobody got offended. Merry Christmas, hope I didn't offend any one with that either.
