stang p/s pump
stang p/s pump
I'm going to use the stock 88 mustang 5.0 serp. belt drive onto my 74 bronco. I need to know what p/s press. hose did you guys use when doing the efi swap. The pumps fitting has an oring which I think is 16mm. the stock broncs p/s box is a standard inverted fitting. I tried google for universal hose kits but all show for a Saginaw pump to a rack/pinion. Also my local hydraulic shop doesn't even know what I'm talking about.
For an 89 Explorer 5.0 serpentine setup, but scroll down to "Plumbing the power steering". Fitting/adapter should be the same. Explorer 5.0 Serpentine Accessory Drive Belt Conversion | ClassicBroncos.com Tech Articles with chart and part numbers.
dusterbd13
12-10-2014 01:28 PM
Handegard
02-17-2013 04:32 PM
