Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-19-2014, 05:46 PM
9thPony's Avatar
9thPony 9thPony is offline
9thPony is starting off with a positive reputation.
Stan's Headers for Highboy
So, I ran into another issue on my Crew Cab build. Its a 1975 F250 4x4 Crew Cab with 390 FE and C6 automatic.
After installing the front drive shaft I noticed that there is very little clearance between the drive shaft and the Hedman 89830 headers.
The Hedmans exit above the drive shaft next to the leaf spring. There is probably about 1" clearance between the top outside of the drive shaft and the header collector. I have about 4" between suspension and bump-stop so I would imagine even with minor flexing of suspension I'll start smashing the two together.
Click the image to open in full size.
I considered fenderwell exit headers, but I'd have to re-do a lot of the master cylinder and proportioning valve lines. I'm also worried that there would be interference with the Borgeson steering shaft.
Since I have not yet set up the pipes and mufflers I'm thinking the easiest (although not cheapest) way to fix this problem is to get a set of Stan's headers which route closer to the block and exit to the inside of the drive shaft.
My question for this thread is whether anybody is using a set of Stan's headers in their highboy and if so how is the fit? Do you have enough clearance around the driveshaft? How about the passenger side and starter clearance? Pics would be great if you have any.
My research so far has turned up nothing but great reviews for their headers so I am reasonably confident the quality will be good.
Thanks!
__________________
Doug
My crew cab build thread
Old 12-19-2014, 07:25 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
Clock the header flange to maximize the clearance as the suspension cycles. I swear mine clears by 1/8-inch and it has yet to hit.
Ya might wanna checkthat your engine is level side to side because that,ll move the header farther away.
Old 12-19-2014, 07:43 PM
hickory1991 hickory1991 is online now
hickory1991 is gaining momentum as a positive member of FTE.
I have a set of Stan's on my 76 Highboy. They are the set that is a little longer to clear the cross member. Clearance seems to be fine. Don't have a real good picture to show you though.
Old 12-19-2014, 07:47 PM
9thPony's Avatar
HIO,
Is that 1/8 over/under like mine or side to side?
Old 12-19-2014, 09:08 PM
HIO Silver's Avatar
Quote:
Originally Posted by 9thPony View Post
HIO,
Side to side. The driveshaft will move very little laterally and it'll be fine so long as it has vertical clearance.
Old 12-19-2014, 09:13 PM
co425's Avatar
co425 co425 is offline
co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.
Quote:
I see one issue between your truck and 9th pony's. He has a high pinion and you have a low pinion. Drive shaft clearance is going to be much tighter between the two.
__________________
1974 F250 4X4
Cummins 12v, NV4500 , np205, Dana 60 Front, GM 14 bolt rear.
Cummins swap/truck upgrade thread
http://m.ford-trucks.com/forums/show....php?t=1181279
LIBERALISM IS PESTILENCE!!!
Old 12-19-2014, 09:31 PM
9thPony's Avatar
Ah, my problem is vertical clearance. If the driveshaft move's up more than about an inch it will hit the headers.
I am probably having the issues due to the high pinion dana 44 (thanks for pointing that out co425) that was swapped in and the 3" custom driveshaft. It's looking more and more like Stans is going to be my best option.
Thanks for the pics Hickory, that helps.
Old 12-19-2014, 10:57 PM
9thPony's Avatar
Found the installation photo's for Stan's Headers on the highboy on their website.
The part number for future reference is 244Y-L. They are Tri-Y headers and can be bought in 14 or 16 ga. with a few coating options. They use 3/8" thick flanges.
This looks to be exactly what I was looking for. The driver's side exits inside the drive shaft and for a nice bonus looks like a lot more clearance to the starter. Wish I would have found these before I bought the Hedman's. I'm sure the Hedman's would have worked well if I had stock front axle and shaft, but on mine doesn't quite fit right.
Anyway, looks like I'll be placing an order Monday.
__________________
Doug
Old Yesterday, 05:51 AM
Quote:
Good eye CO425, I didn't think of that.
Similar Threads
1994 F350 Lifted 4X4 Chrisrehpot Vehicles for Sale 1 09-24-2014 07:32 PM
Stock suspension????? Cj7clay Excursion - King of SUVs 6 09-22-2014 07:40 PM
Putting a ZF 5 in my 79 F350 super cab tklindt 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-29-2014 10:44 AM
Test.... SStans Testing..... 11 07-01-2014 01:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
