Gas tank questions
Old 12-19-2014, 01:27 PM
jason8374's Avatar
jason8374
jason8374 is offline
Gas tank questions
So im looking at getting the 1980 gmc suburban gas tank for my 68 ford f100. It should fit between the frame with out any cutting. I was wondering what you guys did for the sending unit to get it to work with the stock gas gauge. And if you needed to add a vent and return line to it. I plan on running this in my truck and i have the atomic efi system which needs the return line. I have a mustang gas tank but i dont want to cut up the frame for it to work.
http://www.discountbodyparts.com/cat...9-2a0b28fe8b4e
Old 12-19-2014, 01:55 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Yer installing that tank under the bed, right? Then yer gonna run into a crossmember. A better option is a side.fill tank from a 72-80 Scout.... that huge top fill neck on that bowtie tank is gonna requre some extensive clearancing and the tank is gonna hang real low.
I'm running the E-street EFI.... it's sweet.
Old 01-26-2015, 06:52 PM
73axlenut's Avatar
73axlenut
73axlenut is offline
Bump after a month. I too would like to know about the sending unit, someone must have done this
Old 01-26-2015, 10:34 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Best way to solve the sending unit issue would probably get a universal one or try to use the stock one and modify it to work
Brooksy1968
18
12-16-2018 06:29 PM
dferrell5
12-05-2013 04:32 PM
brendaf150
10-22-2013 05:08 PM
reed1951
25
04-18-2008 08:21 AM
paradochs
01-29-2004 08:58 PM
Quick Reply: Gas tank questions
