Gas tank questions
Gas tank questions
So im looking at getting the 1980 gmc suburban gas tank for my 68 ford f100. It should fit between the frame with out any cutting. I was wondering what you guys did for the sending unit to get it to work with the stock gas gauge. And if you needed to add a vent and return line to it. I plan on running this in my truck and i have the atomic efi system which needs the return line. I have a mustang gas tank but i dont want to cut up the frame for it to work.
http://www.discountbodyparts.com/cat...9-2a0b28fe8b4e
Yer installing that tank under the bed, right? Then yer gonna run into a crossmember. A better option is a side.fill tank from a 72-80 Scout.... that huge top fill neck on that bowtie tank is gonna requre some extensive clearancing and the tank is gonna hang real low.
I'm running the E-street EFI.... it's sweet.
Brooksy1968
18
12-16-2018 06:29 PM
brendaf150
10-22-2013 05:08 PM
paradochs
01-29-2004 08:58 PM
