09 f450 troubles
09 f450 troubles
I have a 09 f-450 and it has been causing me lots of problems . But my biggest problem was yesterday while driving down the road the truck quit started flashing all the dash lights and locking and unlocking the doors . I have tried several things and can not seam to get it fixed . I need some help . Thanks JUSTIN
Can't help past that, sorry, might still look for loose grounds.
Think i found the problem by accident . Was checking all the plugs to make sure they was connected tight and bumped the plugs behind the air box that connect to the ecu . Truck then started . So i grabed the plug again . The truck died and went in to lock down again . So in the process of taking the plug apart and checking all the wires to see if there is a busted terminal or pinched wire in the harness .
dmking
01-08-2011 09:30 PM
xTraveler
34
07-23-2008 06:59 PM
