Truck runs too cold. Why?
on
So I had the truck running for an hour today and it didn't even get warm. It was 66* out and the block temp only got up to about 110-120*. AFTER AN HOUR! Granted this was only idling, but still, it should have warmed itself up.
And last winter, I was driving in the snow at about 35mph towing 7000lbs up hills and the engine never got up to temp until I started driving faster and pulling harder.
I think something must be wrong with it, I'm in arizona and I have a truck that runs cold if it's not 100* outside.
Might be time for a thermostat. You may want to pick up a billet thermostat neck also. The stock stamped steel one is junk.
One thing to keep in mind about a hotter thermostat is it also raises your oil temp.
This is a subject that diesel owners like to argue but I will stick with the stock therm.
I remember back in the mid 2000's when Cat decided to run their engines hotter to improve emissions.
I had a nice long chat with a Cat tech about it & long story short they went back to a lower coolant temp.
A hotter engine is like giving it a "microchip" - the fuel burns a little quicker and that's a good thing on a stock-tuned truck. Unfortunately, you throw your oil under the bus in the process. This speeds up its breakdown.
I should point out we're talking about levels that perception plays a bigger role than data.
My default attitude is "Save the oil".
A hotter engine is like giving it a "microchip" - the fuel burns a little quicker and that's a good thing on a stock-tuned truck. Unfortunately, you throw your oil under the bus in the process. This speeds up its breakdown. I should point out we're talking about levels that perception plays a bigger role than data. My default attitude is "Save the oil".
8 degrees is what? Barely 4 percent if my math doesn't fail me.
It certainly is within tolerance of a temp sensor to even be able to notice on the gauge.
What's the tolerance of A thermostat after say 6 months of use?
My shoddy math aside, there are folks here on the forum who regularly do oil analysis. If one were to look hard enough perhaps we could find someone who has tested oil quality on both tstats.
