Cab and radiator mount bushings
I'm working on a 1979 F150 4x4 took the cab off sandblasted and painted the chassis. Now it's time to put the body back on it. The rubber cab body mounts and bushings are shot and needed cut off along with the radiator core support pads. Now I need to find replacements. I called Dennis Carpenter and they only seem to have them for a 2wd truck none for the 4x4. What are all the 4x4 guys doing when you's needed to replace yours? Where can I find them?
Bronco Graveyard has them. That's where I got mine from. You can even get the complete body mount kit that includes all the bolts, washers, nuts, and the hardware for the bed. It literally is everything to go from rad. support to the bed. You can choose between exact repops or polyurethane. And they are a site sponsor.
Here you go #'s for the radiator core support. Thanks to those that provided this. I only cut and pasted it. I myself can not see a difference in 2wd or 4wd??
D3TZ-1000155-B .. Absorber (rubber cushion) - Lower radiator support and lower front & rear cab mounts / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX = 888-727-0418.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
D3TZ-1000396-C .. Absorber (rubber cushion) - Upper radiator support and upper front and rear cab mounts / Obsolete
PARTS INTERNATIONAL
GREEN SALES CO.
Go here https://www.ford-trucks.com/forums/1...l#post14213910
Scroll down to "Parts Vendors & Resources" and have at it.
PARTS INTERNATIONAL
GREEN SALES CO.
I didn't even think about bronco graveyard. I got things from them in the past. Come to think of it I got my transfer case bushings there. The full body kit sounds like that I may need as all the mounts were seized and rusted together so the hardware all needed cut off. Also had to cut acouple of the bed bolts.
^ looks to be the research from NumberDummy? Where is the missing info of the year interchange and models?
I didn't know the body mounts were different from the 2wd to 4x4.
inre to the following, this info is incorrect. 2WD & 4WD is the same.
Carpenter said the thickness was different. Did anyone confirm that?
I don't recall what the OP's application was...that I typed this info for, so I may have typed the applications, may not have.
Carpenter's repro's may not have the same specs as the originals, because they may not be the same as the originals. I know that his 1965/72 upper/lower cushions are "universal fitz-all's."
- 1973/79 F100/350 2WD & 4WD -
D3TZ-1000155-B .. Absorber (Rubber Cushion) - Lower radiator support & lower front & rear cab mounts / 31/32" I.D. x 2 9/32" O.D. x 7/8" thick.
D3TZ-1000396-C .. Absorber (Rubber Cushion) - Upper radiator support & upper front & rear cab mounts / 2 5/32" high (is all the catalog says).
The info is from one of my posts, I also posted the parts catalog pic (here it is again).
Yup definitely will be anti seizing all of them so I won't have to destroy all the hardware next time.
Does Carpenter have the 1973/79 truck parts catalog? If so, does he have anyone that knows how to use it?
I was there in person in 2004, the fellow that waited on me at the counter (Tom) was an ex-Ford partsman. So, AFAIK, he's the only one that can read the catalog....the rest of DC's employees are clueless.
Another glaring error: DC has website that lists all his obsolete parts...and he has a lot of them.
But the website is difficult to use as some are part numbers, but some are also ID engineering numbers (numbers marked on some parts). So, it's a confusing mish-mash.
DC also has his obsolete parts listed on PartsVoice.com and rearcounter.com.
1962/76 Fairlane/Torino, 1967/79 Ranchero, 1977/79 LTD II (not an LTD!) have the letter O as the 3rd digit of their part numbers prefix.
The IDIOT that entered these numbers into DC's website and these two internet search sites used a zero (0) instead!
So when typing the part number correctly into these websites, NONE are listed for DC. When I discovered this crap several years ago, called and spoke w/a gal in the office.
She said she was aware...but added they may not fix the problemo.
Sounds like for being so into ford trucks and offering remanufactured and NOS parts they really don't care to fix the part number mess ups and have the right information. Those things help sell and being organized and correct information help companies get a good reputation. Carpenter is always getting such good reviews from everything that I seen. Makes me wonder why they won't correct the part numbers and give all the right applications on parts they offer. I'm sure they lost many sales because of them not listing the bushings being for 2wd and 4x4 applications. Bronco graveyard is looking a lot better for my cab bushings I like how they offer the full body kit. Anyone confirm that they use quality rubber?
I bought the rubber kit. As they look just like the originals. No alignment issues at all. I also had to get and install the frame savers in a couple of locations. Just be sure to specify if your truck is a styleside or flareside. This is because the bed hardware is different. My truck is a styleside 8' bed, but I got a kit that was for a 6' flareside. No big deal as I didn't need the bed hardware.
