Where can I find this o-ring????
Old 12-18-2014, 06:33 PM
six6six's Avatar
six6six
six6six is offline
Looking to buy a brand new oem o-ring that goes between the turbo outlet and intake inlet... The little orange one... Can't find it online anywhere???
Old 12-18-2014, 06:39 PM
williameub's Avatar
williameub
williameub is offline
I believe this is the one your looking for.
http://www.riffraffdiesel.com/garret...94-5-early-99/
Old 12-18-2014, 06:43 PM
six6six's Avatar
six6six
six6six is offline
I guess I'll order it and find out, thanks for the help!
Old 12-18-2014, 06:54 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by williameub
It is funny how they say they are the same for OBS and early 99 but they are Clearly different
Old 12-18-2014, 07:11 PM
six6six's Avatar
six6six
six6six is offline
Would that be the right one for an obs then?
Old 12-18-2014, 07:15 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Yes, that is the correct one to replace the square cut. We stepped up to Viton instead of Buna-N for longevity.
Old 12-18-2014, 07:35 PM
drpaul311's Avatar
drpaul311
drpaul311 is offline
the ford stealer? that's where i got mine about a year ago or so.
Old 12-18-2014, 08:53 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Thy do use the same oring
Old 12-19-2014, 07:46 AM
Diesel_Brad
No they don't use the same o-ring. The E99 is a much thicker O ring. Been there tried that had had boost leaks. I used up buy a small oil filter for a car and robbing the O-ring from it to seal my E99 spider
Old 12-19-2014, 08:51 AM
MOOSE_MACHINE
Oops. I had the wrong orings in mind. Yeah there's a big difference. When you said yellow I assumed you wher talking about the oil feed and return. Re-reading your post I see you were on th air side of things
Old 12-19-2014, 02:51 PM
HOOTs95PSD's Avatar
HOOTs95PSD
HOOTs95PSD is offline
Old 12-20-2014, 09:14 PM
pilgrimbizket's Avatar
pilgrimbizket
pilgrimbizket is offline
So this o ring goes in between the spyder and turbo?
Old 12-20-2014, 09:52 PM
MOOSE_MACHINE
yes it is...
Old 12-22-2014, 01:07 PM
pilgrimbizket
Hmmm interesting I dont remember seeing one when I installed the spyder. I will have to pick one up
Old 12-23-2014, 04:26 AM
Diesel_Brad
You HAVE to have something there or you would have a SERIOUS boost leak
Quick Reply: Where can I find this o-ring????
