Where can I find this o-ring????
12-18-2014, 06:33 PM
on
Looking to buy a brand new oem o-ring that goes between the turbo outlet and intake inlet... The little orange one... Can't find it online anywhere???
12-18-2014, 06:39 PM
on
12-18-2014, 06:43 PM
on
I guess I'll order it and find out, thanks for the help!
12-18-2014, 06:54 PM
Quote:
Originally Posted by
williameub
It is funny how they say they are the same for OBS and early 99 but they are Clearly different
12-18-2014, 07:11 PM
on
Would that be the right one for an obs then?
12-18-2014, 07:15 PM
six6six
Yes, that is the correct one to replace the square cut. We stepped up to Viton instead of Buna-N for longevity.
12-18-2014, 07:35 PM
on
six6six
the ford stealer? that's where i got mine about a year ago or so.
12-18-2014, 08:53 PM
Thy do use the same oring
12-19-2014, 07:46 AM
No they don't use the same o-ring. The E99 is a much thicker O ring. Been there tried that had had boost leaks. I used up buy a small oil filter for a car and robbing the O-ring from it to seal my E99 spider
12-19-2014, 08:51 AM
Oops. I had the wrong orings in mind. Yeah there's a big difference. When you said yellow I assumed you wher talking about the oil feed and return. Re-reading your post I see you were on th air side of things
12-19-2014, 02:51 PM
on
12-20-2014, 09:14 PM
So this o ring goes in between the spyder and turbo?
12-20-2014, 09:52 PM
pilgrimbizket
yes it is...
12-22-2014, 01:07 PM
Hmmm interesting I dont remember seeing one when I installed the spyder. I will have to pick one up
12-23-2014, 04:26 AM
pilgrimbizket
You HAVE to have something there or you would have a SERIOUS boost leak
