F350 Issues
F350 Issues
I have a ford F 350 super duty XL 40k miles so with that being said here we go
issue 1: Shut truck off a month ago next morning went to start it NOTHING no clicks no nothing so i checked starter its new i checked to see if cylinder was bad its not i can use a screw driver to jump it and i also checked to be sure the wire going to the cylinder had power IT DOES NOT so how i start it is i jump the lead and it starts and runs fine I have replaced the backup netural switch on the trans Still nothing i replaced the sensor under the dash that tells the backup switch its in nuteral or park i have checked the wires no breaks i changed relays and still nothing. only thing i havent done yet is replace the key solenoid where the key goes in
Issue 2: last week the truck was fine driving home when i hit the gas the truck bogged down i replaced the fuel filter and discounted the mass air fuel sensor still acts boggy under a load could it be the cat or throttle pos sensor ?
Issue 3: when we hook up the truck to a computer to check codes the scanners dont see a computer nor pick up their hooked up to anything what would cause the computer to not show up ?
any ideas would def help
thanks
thanks
Battery posts and cables are often overlooked, and just as often the culprit. I fixed a truck of a friend this morning for a no-start condition. He had slathered too much grease on the cable ends. They weren't getting good contact to transfer current.
You could have chewed wires from rodents, etc. Our church van has had this happen twice, triggering a CEL. When I would scan it, there was no power to the port. Both times, some critter had chewed the wires to the OBD port.
An external, visual inspection of the cables and posts isn't sufficient. You can have a light corrosion film between the posts and connectors that restricts the flow of power, or you can have cables that are degrading underneath the outer coating. They can look fine, but not be.
As far as the O2 sensor wiring, I assume that it goes to the ECM. I'm sure someone that knows better than I will chime in and answer that.
Have you followed the wiring to the OBD port? Chewing through that can cut the power to the port that runs the scanner.
new info
ok so i got a different tester today and plugged it in computer talked to it no problem but this is what happened first key was only on for 7 mins truck battery died wont even crank now so im suprised in 7 mins it killed the battery
CODES: i got 11 codes
ABS
C1155 left front speed sensor input circuit malfunction
C1158 Left Front Speed Sensor Coherency Malfunction
B1676 Battery Pack Voltage Out of Range
ENGINE
P1000 On Board Diagnostics II Monitor / drive cycele test not complete NON-MIL
P0325 Knock Sensor 1 Circuit (bank 1) NON-MIL
P0122 Throttle / Pedal Position Sensor A Circuit Low Input NON-MIL
P0171 Bank 1 System Too Lean PENDING
P0174 Bank 2 System Too Lean PENDING
MOD
P0122 Throttle / Pedal Position Sensor A Circuit low input CONFIRMED
Code Summary
ABS - 3 codes
OBDII/EOBD - 3 codes
ENG - 5 Codes
ABS
ENGINE
MOD
Code Summary
ABS - 3 codes
ENG - 5 Codes
I checked the voltage of battery this morning after it nearly died after runnin the computer on it. Read 11.7. So I have it on 2amp charge til I get back from work I'm gonna take it out and have it tested. But still gonna replace the throttle sensor just to be safe
Start there, fix the vacuum leak and replace the battery. Clean all codes and start again.
