1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F250 FX4 CREW 6.0 TURBO DIESEL tow capacity
Old 12-18-2014, 04:14 PM
crossedcannons's Avatar
crossedcannons
crossedcannons is offline
I have a 2004 F-250 FX4 6.0L Turbo diesel Automatic Transmission. There seems to be 2 wts for 5th wheel/gooseneck max tow wt. And really on the table there is nothing for the 250 turbo diesel just for the 350. Does anyone have any information? Here is the link to the table : www.fleet.ford.com/resources/ford/.../towingguides/2004_All.pdf
According to the table it should be 12,700 BUT then there is an asterisk that then says 10,400? and again there is nothing for the 250 turbo diesel...just the 350. Any guidance. I am in the process of getting a new gooseneck horse trailer with living quarters and at the moment it looks like my "big" truck will not be able to handle anything over 10,500. thanks!
Old 12-18-2014, 04:24 PM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Well, your link doesn't work.
Otherwise, you need to list your chassis/can style and your differential ratio.
You're factory rating for 5th wheel/gooseneck towing is somewhere around 12,500 or 13,000 pounds.
Old 12-18-2014, 09:38 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
Also should be considered that those #s are for new '04.....miles and wear should at least be considered for safeties sake
Old 12-19-2014, 08:41 AM
crossedcannons
Thanks. I will try to repost the link.
The truck has only 120K on it and has not been abused at all. It is still is great haul condition and is a powder puff Always serviced on time. Only issue every had was with the Damn ERG or EGR or whatever that darn cooler was called that all the 6.0 folks had issues with. Put an override system in it and it has be fine ever since. Thanks!
One for the road
11-12-2012 10:05 PM
Laurene
11-02-2011 05:56 PM
E30tdf
22
12-27-2010 09:02 AM
skyoung
04-23-2009 02:02 PM
Dan K Martin
02-06-2004 10:45 AM
Quick Reply: 2004 F250 FX4 CREW 6.0 TURBO DIESEL tow capacity
