'79 Bronco Oil Weight - Ford Truck Enthusiasts Forums
Old 12-18-2014, 03:57 PM
bills86f150 bills86f150 is offline
bills86f150 is starting off with a positive reputation.
I recently bought a 1979 Bronco with the original 400 V8 and have noticed a ticking sound when the truck is first started cold. It last for 4-5 seconds then goes away. I'm running 20w50 and a FL1A filter. Is the oil too heavy for it?
Thanks
Old 12-18-2014, 09:13 PM
SDDL-UP SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
My Chilton manual states 20W-50 is okay if you never see temps below 20 deg. F, also shows 10W-30 or 10W-40 good for zero to 100 deg.
I would probably try 10W-40 at your next oil change and just see how you like it. It will protect you engine just fine and may pump to critical areas a little quicker. The downside is you may have slightly lower oil pressure once the engine is hot, depending on clearances.
Old 12-19-2014, 03:26 PM
79FordBlake's Avatar
79FordBlake 79FordBlake is offline
79FordBlake is starting off with a positive reputation.
I run 20w50 in my 78 Bronco's 351M but only because its wore out with oil pressure problems. Everything else gets 10w40 or 15w40.
Old 12-19-2014, 08:15 PM
I tried some 10w30 and it's slower to build up pressure according to the gauge but it no longer has the "no oil" sound that it had when running 20w50 cold
Old 12-23-2014, 07:08 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I've been running Chevron 15w40 diesel oil with Lucas oil stabilizer in my 79 Bronco with a 460. Its pretty much a dedicated wheeler so it gets run hard. No problems here!
Old 12-23-2014, 07:47 PM
Matt Mariani's Avatar
Matt Mariani Matt Mariani is offline
Matt Mariani is starting off with a positive reputation.
A start up ticking sound would be heard in my older higher mileage Ford trucks when they needed an oil change. Changing it would solve this.
Running a thinner oil wouldn't be the solution to ticking imo.
How's your oil pressure?
Old 12-24-2014, 12:56 AM
It has the stock gauge and reads between O and A in normal
Old 12-24-2014, 06:05 AM
I wouldn't trust the stock gauge and really see what it is.
69 Bronco Vinford 1966 - 1977 Early Broncos 2 04-21-2016 11:27 AM
81 Bronco Freewheeling 85MOTORSPORTXLT 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-14-2016 08:34 PM
1988 Bronco II maintenance tsytsa Bronco II 0 04-18-2015 12:13 PM
AC Compressor Oil ??? bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-03-2012 06:20 PM
96 bronco what type of oil???? hatchet 1978 - 1996 Big Bronco 3 10-24-2008 11:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
