Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old Yesterday, 01:27 PM
fordguy62 fordguy62 is offline
fordguy62 is starting off with a positive reputation.
tail lights not working
I have a 79 f250 2wd. All the lights work (headlights,turn signals, parking lights) except the the tail lights. Fuses are good bulbs are good, I tried to check the wiring for any possible shorts and came up with nothing. I tried searching the forum and the only thing I found was that the brown wire is power. Could that be the culprit? Another thing is I checked the grounds and ended up replacing the ground straps. Still no tail lights. What could be the possible culprit? Any help is appreciated
Old Yesterday, 02:14 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Workaholic
77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of
I have read that the taillight bulb housing or socket can cause problems. Also ck the grounds inside the tail light housing area (where the lens goes in the bed).
Head light switch?
Here's what the factory wiring diagram says: for rear lights
Blk/rd= backup lights
Black= side marker, tag lights (on styleside)
Brown=tail lights, tag light (on flareside)
green= RH stop and brake
Yellow/blk= LH stop and brake
Rear light wiring
BROWN: running light circuit
YELLOW with BLACK stripe: driver-side stop/turn
GREEN: passenger-side stop/turn
BLACK with RED stripe: backup lamps
73 & 79 headlight-marker lights use same color codes
Brown= side marker and parking lights
White-blue trace= turn signal
Red-black trace= Low beams
Green-black trace= Hi beams
Black=ground
Flat bed wiring…
Brown= Run Light
Green= Brake light- L
Yellow= Brake Light- R
Black= Reverse Light??
Just wired my front lights. The brown wire is the marker light (side and turn) it is also the top wire on the turn signal socket (three wires in a triangle). The black is ground of course. The white/blue it the turn signal.
__________________
77&79 F250 Rich & Penny
77 351M auto, a/c, add a leaf 33x12.50's
78 (79 headlights) 460 4 spd, 4", a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4, 98 Expedition 4x4, 73 Bronco Hillbilly-Bug
71 Bronco 302 35" Boggers 5.58 gears spool/locker
Old Yesterday, 02:25 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
Automotive Electrical 101 ? Part 1 | Auto Repair Facts
Old Yesterday, 02:53 PM
79FordBlake's Avatar
79FordBlake 79FordBlake is offline
79FordBlake is starting off with a positive reputation.
Did you check the brake light switch? You didn't say in your post.
Old Yesterday, 02:59 PM
Thanks 77 and hio for the info that will definitely help and 79ford I did notice the pedal "falls" down a little and it does cause the brake lights to come on when I pull it all the way up the brake lights go off but I still don't have tail lights
The brake light switch works because when I hit the brakes the brake lights come on. Could it still be bad causing the tail lights to not work? How would I check the switch
Old Yesterday, 06:51 PM
You said "All the lights work (headlights,turn signals, parking lights) except the the taillights."
So I assumed you meant brake lights were the ones not working since I consider parking lights and tail lights the same thing.
For your "tail lights" I would say more than likely you have a bad socket. I've replaced a ton of them.
Old Yesterday, 10:02 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter is gaining momentum as a positive member of FTE.grinnergetter is gaining momentum as a positive member of FTE.
Those sockets can look good....but be bad.
__________________
1973 F250 "the Evil One"
1979 F250
1972 Crew Cab.
Old Yesterday, 10:33 PM
co425's Avatar
co425 co425 is online now
co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.
Quote:
The bulbs also have a tendency to wear down the contacts. So.... check your bulbs as well. Also use dielectric grease when you go back together. This keeps the corrosion away and helps with the vibratory wear on those contacts.
__________________
1974 F250 4X4
Cummins 12v, NV4500 , np205, Dana 60 Front, GM 14 bolt rear.
Cummins swap/truck upgrade thread
http://m.ford-trucks.com/forums/show....php?t=1181279
LIBERALISM IS PESTILENCE!!!
Old Yesterday, 11:25 PM
Scoop531 Scoop531 is offline
Save Me From My Dents
Scoop531 is gaining momentum as a positive member of FTE.
Scoop531 Scoopsmp3s
First question are the rear side marker lights working
If not
Do you have a test light or multimeter if so I can help you narrow it down a lil
At the rear drivers side of the truck near the end of frame rail there should be a square plug.
This is the harness for all the lights for the bed
Unplug this turn lights on and check all 4 prongs on the harness from cab side with the meter or light if one lights up then you are getting power from the cab and now can narrow down to harness to bed side of circuit
Report back
Old Yesterday, 11:40 PM
HIO Silver's Avatar
There is no excuse these days for not having a multimeter. Harbor Freight provides a coupon for a free multimeter and if ya can't find a coupon, they are still only around $10... that's two Starbucks lattes or three beers from the local watering hole. If in CA, then it's only two beers.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
