I have killed my truck for the first time and don't know why!
Well, I have killed it and while I am sure this won't be the last time, I haven't got a clue why it won't start. As you can see in my signature it's a 7.3, I removed the banjo bolts on the ends of the heads to drill them out. Put them back in, buttoned everything up and it's a no start. Also, this thing is making a ton of noise and won't stop. Something used to build vacuum? NO idea. Does anyone have a clue? It just cranks and the batteries died pretty quick after trying about 3 or 4 times to start it. Thanks!
You made the same mistake I did back in 2008 listening to a guy by the name of Bill Hewitt. You'll need to buy some new OEM bolts to replace them.
While you're fidding with the fuel system, consider these mods:
Fuel Rail Crossover? (FRx) - Riffraff Diesel Performance
High Flow Fuel CVD Fitting Set - Riffraff Diesel Performance
Fuel Rail Banjo Bolt - Riffraff Diesel Performance
One stop shopping and you come out better in the end.
Yea actually I saw another video of a guy doing it too and who doesn't love free mods right? I posted on the 7.3 forum and the one response I got was that drilling the banjos is fine, but idk. Mostly yesterday I learned that I don't know a thing about diesels lol. I got it running fine and it drives great now. Apparently I had to work the air out of the system for it to smooth out. So I'll see how it goes, but yea last night I saw the replacement bolts on Riff Raff's site, I was thinking I should get some jic. What did it do to your truck when you drilled them? Thanks for the links, I will check those other things out too. And thanks for not making feel like a jacka$$
Here is our high flow bolts as well.
http://www.riffraffdiesel.com/riffra...njo-bolt-7-3l/
My truck liked it initially, but it drank down diesel like you wouldn't believe. So I ended up having to replace the banjo bolts with some new OEM. That's why when Clay came up with the first gen Frx, I snatched it up.
Just noticed this on Riffraff's site: Riffraff Diesel High Flow Banjo Bolt - 7.3L - Riffraff Diesel Performance
I think you'll be better off with these as they're specifically engineered for more flow. My 6.0 is getting some of these after the Holidays!
You should be fine. Just keep an eye open for fuel leaks.
Got the new High Flow Banjos from Riff Raff today. They are installed and all is well again in Texas.
Here's a few notes about the install:
1. These do NOT come with O-rings so just be aware that you have to reuse your old ones or buy new ones separately. While removing the stock rear banjo, the o-ring fell off into the void of the engine bay never to be seen again. Thankfully I have an o-ring assortment and was able to find one that fit. So just be careful!
2. The new banjos have a 10mm hex head instead of the 1/4" drive square slot like the stock ones. Getting a 10mm wrench on the rear banjo was a bit difficult, I found it easier to go from underneath to tighten it.
3. The front banjo is actually easier to get to with the wrench instead of trying to fit the ratchet into the slot like stock.
They seem to be really high quality and thread in nicely. Now it's time to take it for a ride!
We also suggest a ratcheting wrench for better clearance on install.
Victor Aguilar
1999 to 2016 Super Duty
11-14-2015 02:40 PM
motionmarineaudio
11-30-2007 07:44 PM
