64 F500 Engine & Exhaust Info
Greetings Gurus! New to the site and looking forward to the resourcefulness of the forums here! I recently purchased a 64 F500 and have little information to go on to start getting it back to life. There is a V8 in place but it is not original and the owner could tell me little about it other than it was a motor from the same era as the truck itself. I need to run full exhaust from the manifolds but with no motor specs and little help from the parts stores, I'm having little luck narrowing down to the exhaust flanges I need. Can you offer advice on identifying this motor and maybe some direction for acquiring the 3-bolt flanges to tie in new exhaust? I really appreciate your time and knowledge, and I look forward to conversations with you folks going forward!
Some 1964 V8 F500's came with the 292, has the dizzy behind the carb.
Otherwise, all other 1964 & 1965/78 V8 F500s came with FT engines (dizzy in front of carb): 330 2V M/D - 330 2V H/D - 361 2V - 391 4V
These FT trucks came with Rams Horn exhaust manifolds, which are the same right & left.
If it doesn't have the Rams Horns, the engine may have been swapped...look on the manifolds for numbers, post what they are.
jwhorsefolk
11-22-2017 11:02 AM
Harrier
08-07-2014 03:19 PM
pineconeford
07-27-2013 03:47 PM
pmh
16
12-06-2012 06:22 AM
