narrowed down to a vacuum leak
Old 12-18-2014, 12:26 AM
copen93's Avatar
copen93
copen93 is offline
Not loosing any more coolant, guess it was just air being purged with the bubbles. I have been seeing some vibration with the motor at idle. Also when I start the truck it has a high idle for about 20 seconds then calms down. I hear a very very very slight misfire through the tail pipe very randomly. I finally got some money and wanted to know the best way to go about finding this leak? 1993 f150 4.9 300
I will be replacing fuel filter, air filter, and most likely cap and rotor, will clean the injectors with maybe seafoam. I will run the codes at autozone when I go get my new parts.
Old 12-20-2014, 09:12 AM
spacegrass's Avatar
spacegrass
spacegrass is offline
Autozone won't be able to run your codes on your 93, but the good news is you can do it yourself with just a paperclip or a short length of wire.
Find this, located on the drivers side front fender, usually under a cover that says DIAGNOSTIC PORT or something I'm sure someone will correct me on.
Attach a jumper wire (or paper clip) between these two.
Hop inside the truck, turn the key, and watch the check engine light flash. Count the number of flashes. I like to have my phone on me to record it, in case I miss one. You can also perform an on demand running test by starting the engine.
Here's some light reading:
EEC IV Self Test hookup
EEC IV 3 digit codes
If you navigate around that site, it will tell you all you need to know about testing and retrieving trouble codes.
Old 12-20-2014, 09:19 AM
spacegrass's Avatar
spacegrass
Also, the easiest method to check for a vacuum leak is a can of Throttle Body Cleaner. Spray around certain areas, and see if there's a change in engine RPM with the engine running. Also, check on that white vac line near the blower motor that always rots itself away.
Old 12-23-2014, 08:12 PM
87-XL-Squared's Avatar
87-XL-Squared
87-XL-Squared is offline
Old 12-23-2014, 10:49 PM
copen93's Avatar
copen93
copen93 is offline
Welp, I finally got around to figuring out how to decipher the codes and I got the 634 code after the interment or whatever. Any ideas how to fix this? No wonder my truck sorta clunks when I shift from park to drive etc
Old 12-23-2014, 11:49 PM
copen93's Avatar
copen93
copen93 is offline
[QUOTE=copen93;14932657]Welp, I finally got around to figuring out how to decipher the codes and I got the 634 code after the interment or whatever. Welp I got some bubbles in my coolant again, the mixture isnt right from what I know so I am guessing my coolant is turning brown because of the rust, although it can be ... oil 😒 I am going to do the running test tomorrow.
Old 12-24-2014, 04:53 AM
DeepSeaDynamo's Avatar
DeepSeaDynamo
DeepSeaDynamo is offline
Where does the other end of that go?
BigBodySage
06-06-2013 10:56 AM
eco
19
10-24-2007 04:44 PM
southsidej
05-30-2005 06:22 PM
Demicon
02-23-2005 01:39 AM
mainernexile
Modular V8 (4.6L, 5.4L)
07-23-2004 10:34 AM
Quick Reply: narrowed down to a vacuum leak
