1978 - 1996 Big Bronco
Bronco body, HD frame?
Old 12-17-2014, 08:27 PM
cajohnson's Avatar
cajohnson
cajohnson is offline
Gentlemen,
Are the truck frames (i.e. F-350) any stronger than a stock Bronco frame?
Old 12-18-2014, 10:03 AM
andym's Avatar
andym
andym is offline
Yes, they are much stronger. Also the rear of the Bronco frame curves upward right behind the cab. When you're in a Bronco, look behind the front seats and that 6" rise to the rear seats is also reflected in the frame. The HD/SD frame is flat from the cab back.
Old 12-18-2014, 01:41 PM
cajohnson's Avatar
cajohnson
Laying in the snow. . .
Thanks for the comments!
There is an '83 parts Bronco a few miles away so, based on your comments, I decided I had better go look at it again. I see the fairly abrupt rise in the frame. I also see the brackets on the side of the frame for the six body-mounts. Based on a sliding caliper, the sheet metal in the frame measures about a sixteenth of an inch thicker on the F-350 than on the Bronco.
However, I do note that the F-350 frame does have a rise in it starting under the cab, but it is more gradual than the Bronco's.
What would be really cool at this point would be to have a Bronco frame right beside the F-350 frame.
Is anybody aware of a good thread on using a Bronco body on a truck chassis?
martins2141
02-21-2011 05:55 AM
havi
WTB - Ford Trucks & other vehicles
07-04-2010 12:37 PM
Black_Stallion
03-21-2010 02:14 PM
Twohands
02-23-2005 09:06 AM
snackboy
03-04-2003 08:28 PM
Quick Reply: Bronco body, HD frame?
