Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
Old 12-17-2014, 09:27 PM
cajohnson cajohnson is offline
cajohnson is starting off with a positive reputation.
Bronco body, HD frame?
Gentlemen,
Are the truck frames (i.e. F-350) any stronger than a stock Bronco frame?
__________________
Chris
'86 F-350, 460ci, 4-sp MT, 4x4, 1345, SRW, standard cab, 133" WB, Dana 60 KP front, Sterling 10.25 rear.
Old 12-18-2014, 11:03 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Yes, they are much stronger. Also the rear of the Bronco frame curves upward right behind the cab. When you're in a Bronco, look behind the front seats and that 6" rise to the rear seats is also reflected in the frame. The HD/SD frame is flat from the cab back.
__________________
Andy
2000 Excursion Limited 7.3L 4x4
"If you want to live in a country that manufactures things, you need to buy things that your country manufactures." - Mike Rowe
Old 12-18-2014, 02:41 PM
Laying in the snow. . .
Thanks for the comments!
There is an '83 parts Bronco a few miles away so, based on your comments, I decided I had better go look at it again. I see the fairly abrupt rise in the frame. I also see the brackets on the side of the frame for the six body-mounts. Based on a sliding caliper, the sheet metal in the frame measures about a sixteenth of an inch thicker on the F-350 than on the Bronco.
However, I do note that the F-350 frame does have a rise in it starting under the cab, but it is more gradual than the Bronco's.
Click the image to open in full size.
What would be really cool at this point would be to have a Bronco frame right beside the F-350 frame.
Is anybody aware of a good thread on using a Bronco body on a truck chassis?
__________________
Chris
Similar Threads
96' bronco - 99' superduty frame? Fordman96 1978 - 1996 Big Bronco 5 10-22-2011 11:18 PM
bronco 2 frame ledhead617 Bronco II 1 11-11-2010 06:43 PM
Bronco body on pick-up frame? robbie42301 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-26-2010 09:24 AM
Windshield Frame Removal councilman 1966 - 1977 Early Broncos 3 04-09-2010 05:32 PM
Ranger body on a bronco frame jerrytown2001 1978 - 1996 Big Bronco 1 12-10-2006 10:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
