Merry Christmas to Me!
Wow, what a response. Thanks everybody. After reviewing all of those videos, my worst fears are confirmed. And, my knees are not as young as they used to be, so the idea of getting down on the concrete to carefully position the 2-post arms is not appealing. I will be getting the four post lift with the optional air jacks mentioned earlier. Now, all I have to do is research the manufacturers. I can afford a new unit, but if I can find a used one for about half price, I will probably go that way. This was the most info I have seen in one place for helping to insure proper purchase and use of a lift. Thanks again Jag
If you get the 4 post you might want to also consider these, they are a hole lot lighter than trying to wrestle steel ones around.
Hook Nosed 14x5 Rack Ramps - Car Lift Ramps
Gerrymoe, thanks for the offer. I can definitely use those ramps if I get the Bend Pak. However, I will be using them in the Fallbrook area instead of Sacramento, as my title reads. For the time being, we are just going from north to south and back again, but eventually we will be all set up in the south. How long are the ramps? Maybe I can fit them in our Durango on our next trip down in January.
Thanks again, Jag
Thanks again, Jag
Jag, the ramps are normally removed and there are plates that slide in the slots that act as a safety stop.
You are welcome to the extra set I have, just drop me a line and I will get you my address. I am only about 6 miles off 99 straight shot to my place
Jag
This is a picture showing the front wheel block attachment connection laid down.
These are the front wheel block in the upright position
Shows the rear ramp in the lift in the raised position. These are the extended ramps for the bend-pak and exact as the ones I have offered to ya
This shows the mounting attachment pins ro the ramps. These ramps are on the heavy side and as Chuck say don't want to be toting thes around, another reason I leave them on. Takes ya awhile to duck when ya go by them but now to me it is automatic
I will say this, get a lift to fit your needs.
If you are going to store a vehicle then a 4 post with some bridge jacks. It is more of a pain to work on a 4 post due to the lift getting in the way of repairs but it is much "safer" due to less risk of a 2 post arm not being properly set/positioned.
Now, if you are going to do a bunch of misc work on your car or other cars especially if you plan on tearing apart front suspension then a 2 post is the best bet.
With a 2 post the concrete footing is crucial because the hoist has to "balance" when supporting a vehicle. It is also even more important that you properly place the vehicle and account for removing engines etc and use a T stand to support the vehicle in repair.
#29
Do what you can with what you have!
catfish101
105
12-26-2008 03:34 PM
