1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 F250 4x4 front hub replacement
Old 12-17-2014, 05:13 PM
Whiteroom_Guardian's Avatar
Whiteroom_Guardian
Whiteroom_Guardian is offline
Been hearing that familiar "clunk" sound when turning slowly into a parking spot. Jacked it up today and there is about 1/4 to 1/2" of play in the driver's side front wheel when pulling hard on the wheel from side to side.
Luckily no vibration at speed....yet. I drive at least 100 miles every day on the highway. Gotta change this now.
I assume that the needle bearing maintenance guide on guzzler's site will not remedy this kind of play, correct?
Gotta just replace the whole assembly, right?
Other than sockets, and air hammer, some PB blaster, snap ring pliers, and a jack/lift, and a new hub, is there anything else I should make sure I have before I rip into this job tomorrow after work?
Any simple mistakes to try and avoid?
Thanks
Old 12-17-2014, 06:29 PM
slpcth's Avatar
slpcth
slpcth is offline
A foot pound torque wrench to torque the unit bearing,caliper and tire back on and brake kleen to clean the rotor surface.
Old 12-18-2014, 08:40 AM
Whiteroom_Guardian
So now I don't think its the bearing after all. Before I bought the hub I wanted to double check. Just jacked it up again and the play was gone from top to bottom. Drove it around the lot a few times making some slow sharp turns until I heard a single "clunk" sound. I then jacked it up again.
Picture the wheel as a clock face when looking at it from the side facing the lugs. Top is 12 oclock, etc.
When I pull/push on the wheel at 12 oclock or 6 oclock there is no play, but when I pull/push at 3 oclock or 9 oclock there is side to side play. So tie rods or something?
Old 12-19-2014, 08:55 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
not really
the lack of play at 12 and 6 vs the play at 3 and 9 could be due to the weight of the wheel. to get a better sense of the play at 12 and 6, place two boards under wheel and slightly jack the tire so as to take some of the weight of and the play at 12 and 6 will be more pronounced. the two boards are needed to reduce the friction of the rubber tire on the first board. boards should be abot 6 wide and 6 long, thinner the better, 1/4 ply works well.
Boilermaker1994
04-10-2017 05:46 PM
Randy Sheats
12-23-2016 02:41 PM
boatbanditf250
03-18-2010 02:22 PM
shenders99
09-07-2006 05:15 PM
IM1096
01-03-2006 07:58 PM
Quick Reply: 2008 F250 4x4 front hub replacement
