Found in oil pan, what is it!!??
Only 1 end is tapered slightly, other end cut square.
It came in with power loss at highway speeds. Found HP oil losing pressure. Was diagnosing that problem when I found the oil leak at the pan gasket. After I drained 25 litrers of oil out of pan, I found fuel leaking from both cylinder heads. Truck has been running as smooth as a 6.0l runs until this point! I just don't want to forget about the pin, spend a bunch of money on it now to get it back together and find out the pin was important! 356000kms on engine. It has had both heads replaced and injectors done more than once in the past....
I think that may be something accidently picked up off the work bench when the heads were changed and maybe dropped into a oil drain gallery. Done that before only it was u-joint needle bearings.
I can think of nothing on a 6.0 that that size pin/dowel would fit except maybe the front cover dowels.
May also be the dowels for the LPOP stator.
I would have to dig out some assembly diagrams.
But What about the front cover and oil pump cover.
Are they pined in place?
Cam pin should be easy to check with the engine out on a stand.
Flip it so you can shine a light in the sensor hole and turn crank
shaft over and you should see it somewhere in the 720º of rotation.
That is if you thinking the trigger pin. The gear pin might be harder.
One place that would be better to ask would be at an International
Service Shop. I know the mechanic at the one I get parts at is so
much more a mechanic that what you find at most dealerships.
Sorry guys but You can be a mechanic and work at a dealership but
you most likely will find yourself surrounded by simple tech want-to-be
that RTV things that they are too lazy to go to the parts counter and get
an O-ring for. (Yes I still want that guys head on a platter)
Sean
Sean
Mustang Cowgirl
23
08-14-2014 01:41 PM
gentlemansbeard
01-28-2012 12:46 AM
BlueRanger94
Oil & Lubrication
24
03-14-2004 07:38 AM
