03 Escape V6 Pegs Needles On Acceleration
Not always & seemingly at random. Just like at startup after battery reconnect.
Most searches come back only with incidents at startup only. Recommendations say battery &/or alternator. Battery is Optima Red that's been in there maybe 6-7 years and all connections are clean & reads 12.48 at rest.
Alt is a AC Delco new unit replaced 20k or so ago & reading 14.24 at idle with or with out any accessory drain on the system or RPM.
Troubling thing is a code for coil misfire on # 5 which put it into limp mode (I erased & so far hasn't returned) & some comm issues with the Inova 1403 that I'm using.
Any recommendations?
At this age, both the battery and the alternator are suspect.
The battery needs to be load tested to see if it's failing. The output of the alternator needs to be checked while it's driving to see if it's intermittent, usually due to worn brushes starting to "float" and loose their connection.
Follow up...
Dug out my load tester & checked the battery: Dropped to 9.5 during test which is weak & should be replaced.
Drove a route with DVOM hooked to battery and different loads on engine. Average output 14.24 to 14.48 so I think that's OK.
After swapping #5 coil to #6 position & seeing fault code move, I replaced the coil with a parts house unit till I can get to the junk yard & grab a selection of stock coils for the future.
Here's the kicker... No more pegging the needles since coil replacement. Several days here lately of 20s-teen over nite temps & no degradation of cranking energy that you would expect from a weak or dying bat.
WheelerJeremyS
06-20-2018 07:44 PM
jimho
1983 - 2012 Ranger & B-Series
01-08-2012 11:13 AM
