general OBS questions
Old 12-19-2014, 06:31 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
2wd trucks are coil spring fronts.
4wd are leaf. Because the front leaf attachment point to the frame is also the pivoting shackle, the front of the frame is boxed. Whereas the 2wd is not boxed, only solid on 3 sides. This is true be they a F250 with the independent TTB or F350 with the solid D60.
This is the front frame horn of a 4x4 frame…compare how it looks to yours.
  #32
Old 12-19-2014, 07:05 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by BoomerTexas70's
I do like that automated safety hitch, and think i would be great use for a smaller like expedition but the length of the excursion/ my build i feel is just right.
You said that they were no leaf spring provisions. Does this mean that ALL 250/350 2wds were built like and IFS, no straight axle?
Thanks Boomer
Yes all 2wd F150, F250, F350 were coil springs and TIB with NO STRAIGHT axles
  #33
Old 12-20-2014, 10:12 AM
BoomerTexas70's's Avatar
BoomerTexas70's
BoomerTexas70's is offline
TIB, what is that? Can it also be refered to wish-bone front end?
Thabks Boomer
  #34
Old 12-20-2014, 11:07 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Thabks Boomer
TIB= Twin I-Beam Ford terminology for the 2wd truck front end
No, I would not refer to it as a wish-bone front end.
  #35
Old 12-20-2014, 11:35 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I wouldn't either, but I think some people do. Twin I Beam is what it has always been called until on-line forums made typing it too hard, so it got abbreviated to TIB.
  #36
Old 12-20-2014, 09:34 PM
Diesel_Brad
TIB = Twin I Beam(what has been on for 2wd trucks since 1965
TTB = Twin Traction Beam(used on the 4wd trucks from 80-97) excluding 85.5-97 F350s and 97 F150
  #37
Old 12-21-2014, 04:29 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
You could use '05-up Super Duty axles to convert the 2wd to 4wd. Coil spring front suspension, so there's no need to worry about leaf spring mounts for the front.
  #38
Old 12-22-2014, 09:23 AM
BoomerTexas70's
Thank ya'll for thr info on TIB.
That would be easiest swap then? And as far as converting between transfer case and differential, can the drive shafts be used from the donor, or would i have to order some?
Thanks Boomer
  #39
Old 12-22-2014, 03:41 PM
Bob Gervais
Thanks Boomer
Into a 2wd, I think it would be fairly easy. You may be able to re-use driveshafts, though I think the Super Duty uses a larger u-joint. There are conversion u-joints though, one cross will fit the OBS driveshaft, the other cross fits the larger Super Duty diff.
I'm unsure if Super Duty driveshafts will fit onto the splines of an OBS transfer case.
I'm actually gearing up to swap a set of these into my 95 F150 4x4, so I'm not 100% positive on driveshaft lengths and fitment just yet.
Super Duty axles are dirt cheap, compared to their OBS counterparts. I paid $800 for front and rear axles, coil spring buckets, radius arm brackets, all steering components, steering box, and track bar. They came out of an 06 with 60k-ish miles on it.
Installation is fairly easy, there's quite a few swap threads to be found doing a google search for "obs super duty axle swap".
  #40
Old 01-05-2015, 07:48 AM
BoomerTexas70's
Just an update, this is not a dead thread. Im just going to have to put it on hold, seeing as my wife and i lost our job.
Thank ya'll for your patience,
Boomer
  #41
Old 01-06-2015, 03:35 AM
Bob Gervais
Well, that sucks. Hope it all works out soon!
  #42
Old 01-06-2015, 09:42 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Here's a set of OBS axles with 4.10 ratio, in New York for $750. Freight might be a little expensive...
PowerStrokeNation : Ford Powerstroke Diesel Forum
  #43
Old 01-09-2015, 11:39 AM
BoomerTexas70's
Thank ya'll, found a job waiting on back ground check.
Back to questions,
Were there any AT ALL 4wd dually obs trucks, stock that is.
Thanks,
Boomer
  #44
Old 01-09-2015, 11:49 AM
FordxFour's Avatar
FordxFour
FordxFour is offline
F-350 cab and chassis
  #45
Old 01-10-2015, 05:36 AM
Diesel_Brad
Back to questions,
Thanks,
Boomer
Cab-n-chassis ONLY. NO 4WD dually PICKUPS were made from the factory until 1999
Quick Reply: general OBS questions
