Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 07-19-2003, 01:04 PM
billu12 is starting off with a positive reputation.
97 ford f 150 factory alarm reset
Ihave a ford f150 97 model. I pulled on my door handle without thinking and noticed the alarm did not go off. I would never know it except that the alarm did not go off. Panic button works. It chirps when i lock or unlock the door, lights come on. the alarm just does not go off. The little red light on my dashboard blinks funny. like this: blinkblink, blinkblink, blinkblink, kind of fast but thats it. anyway I can reset this?
kind regards,
erni
  #2 (permalink)
Old 07-19-2003, 06:37 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Mine doesn't go off if I open the door with it set. I think that the security on these is just for the correct key to start the truck. Mine will flash when I turn it off and remove the key, but when I lock the doors, like yours, the lights flash and horn will beep if you hit the lock button twice, but my light in the dash doesn't flash once it is set.
Jimmy
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 07-19-2003, 09:58 PM
NDrum2005's Avatar
Texan
NDrum2005 is starting off with a positive reputation.
I have a dealer installed Ford alarm in one of my cars. I have noticed that the red light flashes in a blinkblink blinkblink pattern, and the alarm didnt work when the door handle was pulled. The manual said that it was in "Vallet" mode. To get it back to normal just push on the red light. The next time i locked my car, the alarm sys. was back to normal. Dont know if this will work for you, but its worth a shot.
__________________
2006 F150 Reg. Cab STX 4x2, V6 Auto, 3.55 gears
  #4 (permalink)
Old 07-20-2003, 01:01 AM
LxMan1's Avatar
My theft light is in the instrument panel, not touchable.
Jimmy
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 07-20-2003, 10:03 PM
Thank's to all who replied to the message on the alarm.
I pushed down on the blinking red light on my dash board and it was reset!
Thank's again.
  #6 (permalink)
Old 07-21-2003, 10:04 AM
Jim242002's Avatar
Jim242002 is starting off with a positive reputation.
My factory alarm on the 97 does not go off if it's locked and someone trys to open the door...All the lights will come on inside the truck for about a minute then click off...If you unlock it from inside out it goes off...So if someone broke the window would it go off?
Also my theft lights comes on when you lock it and it stays on for about 30 secs then it goes off
Quote:
Jimmy
Thats how mine is...How can you touch it?? does it have a button anywhere else?
__________________
2000 F-150 Supercab Lariat
V8 5.4L K/N Cold Intake
Leveling Kit
Westin Brush Guard
14'in Magnaflow
Buckshot Tires (Yummy)
  #7 (permalink)
Old 07-21-2003, 10:36 AM
pilot10 is starting off with a positive reputation.
Quote:
Originally posted by Jim242002
My factory alarm on the 97 does not go off if it's locked and someone trys to open the door...All the lights will come on inside the truck for about a minute then click off...If you unlock it from inside out it goes off...So if someone broke the window would it go off?"
"Also my theft lights comes on when you lock it and it stays on for about 30 secs then it goes off"
"Thats how mine is...How can you touch it?? does it have a button anywhere else?
If the window is broken it should go off. The manual details how to set the sensitivity level. Pulling on the door handles with the alarm set should trigger the alarm. Mine is that way- pretty annoying sometimes- so I just leave the alarm in valet mode unless I'm somewhere I feel the need to set the alarm.
This is how this system works- It is not an alarm but a passive anti-theft device.
The flashing button, usually found under the dash, is for the alarm
Pressing the lighted button will turn off/on the valet mode (button blinks rapidly twice when in valet mode).
__________________
06 F150 King Ranch
  #8 (permalink)
Old 07-21-2003, 10:42 AM
Jim242002's Avatar
pilot10
So to change the sensitivity level..Their should be a button under the dash to do this...??
My manual never said much about it just about the light will stay on 30 secs after you lock the vechial
__________________
Leveling Kit
Westin Brush Guard
14'in Magnaflow
  #9 (permalink)
Old 07-21-2003, 10:59 AM
NDrum2005's Avatar
Texan
The factory alarms usually wont have a pushbutton/light, they will just have a "THEFT" light in the dash that flashes. They really arent alarms either. The only way for the alarm to sound is if you push the panic button on the remote, or if you lock the car with the remote, and then open the door from the inside, or picke the lock and open it form the outside. So, the alarm wont sound if just the window is broken, the door has to also be opened either from the inside or by picking the door lock form thew outside. Also, these factory "alarms" dont have a siren. When the alarm is set off, the horn honks and the lights flash. Also, when the lock/unlock button is pushed on the remote, there probably wont be a chirping sound.
The dealer installed alarms (either Ford brand or another brand) will have a siren. They will go of if the door handle is pulled, glass broken, etc. Usually they will have have vibration/noise sensors. So, if a loud semi drives by, it could set off the alarm. These alarms also have a red light that flashes, that also doubles as a push button to change the alarm from normal mode to valet mode. Valet mode makes the alarm work like the factory installed ones. The alarm will only sound if the panic button is pushed, and the doors will lock/unlock from the remote as usual. The red light should flash in a blinkblink...blinkblink... pattern when in valet mode.
Hope this helps.
__________________
  #10 (permalink)
Old 07-21-2003, 11:14 AM
My apologies. I wasn't aware of the "stock" alarm. I have a dealer installed alarm with the siren. The sensitivity switch is on that alarm system.
Tim
__________________
06 F150 King Ranch
  #11 (permalink)
Old 05-16-2008, 10:09 AM
JUSTINRVS is starting off with a positive reputation.
Can You Help Me...i Have A 1997 F150 5.4...i Was Unloading My New Box Last Night With The Key In Accy Place Listening To My Raido, My Bat Has Plenty Of Power, Nothing Was Touched, Truck Ran Seamlessly All Day, But When I Got Back In It To Move It, I Turn The Key Nothing...all Lights Come On As They Should, But No Start, If I Pop The Starter The Truck Runs Fine, But The Key Is Being Cut Off By The Stock Alarm As Much As I Can Figure...i Just Got The Truck, It Has A Standard Key, No Key Fob And Has Not Messed With Me At All...
Any Ideas How To Bypass???
Please Let Me Know!!!
  #12 (permalink)
Old 05-16-2008, 10:17 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
You do not have an alarm issue since your truck didn't have one from the factory.
You have a common "no crank" issue with your starting system unless your vehicle has been modified from stock.
Tips:
1) Search first, ask second
2) Avoid reviving long dormant threads
3) Please do something with your capitalization......that is painful.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #13 (permalink)
Old 05-16-2008, 11:28 AM
bamafordguy97's Avatar
bamafordguy97 is starting off with a positive reputation.
Mine goes off if you bump the thing to hard. I bought it used but I believe it is still stock. LOL Not really sure. I still have the Factory Key Pad and everything
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
